Interesting. I'd assumed it was a piezo for a moment. Then the datasheet said otherwise. Actually, it's quite similar to some cheap earphones they used to make -- circular, very thin disk of metal over the top of a circular magnet with a coil present. It'll work over a modest audio range. (I used to dismantle them to see how they worked when I was a kid.)
The datasheet says they require \$\approx 35\:\textrm{mA}\$. But I think that's a mean value, since they are operated typically with 50% duty cycle. (And because the datasheet actually says "mean current", too.) The resistance is given as \$42\pm 6.3\:\Omega\$. So worst case collector current should be \$\frac{5\:\textrm{V}}{35.7\:\Omega}\approx 140\:\textrm{mA}\$ with your \$5\:\textrm{V}\$ rail.
Let's look at the PN2222A curves for a moment:
Entering into this (typical) set of curves, I can see that the \$150\:\textrm{mA}\$ curve flattens out starting at a base current of about \$I_B=5\:\textrm{mA}\$ and is pretty solid by \$I_B=10\:\textrm{mA}\$. So I'd decide to drive it with \$I_B=10\:\textrm{mA}\$ as a reasonably safe choice.
This curve tells us something about \$V_{BE_{SAT}}\$:
I see that \$V_{BE_{SAT}}\approx 850\:\textrm{mV}\$, typically. Let's call it \$V_{BE_{SAT}}= 900\:\textrm{mV}\$ and be safe. The missing bit is the drop from your I/O pin, when high. But my own experience says that you shouldn't expect a drop of more than \$500\:\textrm{mV}\$ when applying \$10\:\textrm{mA}\$ out of a \$40\:\textrm{mA}\$ output.
So your resistor value is \$R_B=\frac{5\:\textrm{V}-900\:\textrm{mV}-500\:\textrm{mV}}{10\:\textrm{mA}}= 360\:\Omega\$. I'd go with a \$390\:\Omega\$ resistor and then take a voltage measurement or two, just to be sure.
Keep in mind that this is a pulsed application. So it's not solely ON and the datasheet's current is listed as "mean current" which does NOT MEAN that this is the actual peak current when turned on.
The BJT power will be \$900\:\textrm{mV}\cdot 10\:\textrm{mA}+100\:\textrm{mV}\cdot 140\:\textrm{mA} < 25 \:\textrm{mW}\$ at 100% duty cycle. So at 50% duty cycle, there's just no worry about using a TO-92 packaged device. You are fine with the PN2222A here. Similarly, the resistor power is \$390\:\Omega\cdot \left(10\:\textrm{mA}\right)^2 < 40 \:\textrm{mW}\$ at 100% duty cycle. Again, most any resistor package will be fine.
