I have an RGB Led strip that I want to use for just white light. I currently use an arduino with some transistors to control each colour. I have now no need to have different colours and I think my LED strip is not as bright as it could be due to the transistors I am using.
If I want to just use it as a white LED strip, can I just connect the +12 volt to +12v on the strip and the RGB pins to ground without the transistors or the arduino?
