I'm designing another Silicon Photomultiplier circuit. Right now, it is in the theoretical stage. My team and I have made numerous circuits, and the basic template is below:
Below are some links to the main parts used:
https://www.digikey.com/product-detail/en/texas-instruments/OPA656N-250/OPA656N-250CT-ND/431967
http://sensl.com/estore/microfj-60035-tsv/
The amplifier is the Texas Instruments OPA656 op amp. It contains a slew rate of 295 V/µs and a bandwidth of 500 MHz.
The Silicon Photomultiplier (SiPM) is a SensL MicroFJ-60035-TSV, the 6 mm version. It contains a PDE of 51%, and it has a gain of 5.3*10^6 from the anode to the cathode, and a typical dark current of 4.1 µA, with a rise time of 300 ps, and a max current limit of 15 mA.
The resistors and capacitors can be adjusted as needed, but this is what my team is working with so far. We have two channels, each independent of each other in this configuration, and the team is trying to measure coincidences between the two. Now, my training is as an electrical engineer, not a nuclear engineer, so this is all new to me, but from what the team has told me briefly, between measuring the time between the two detectors, we are getting around 400 ps. Now, I'm not sure if this is the time difference between the two channels or if this is the rise time of one individual channel, but when I find out more information, I will update this accordingly.
The timing is good, but because the amplitude was smaller than what we require, we had to use an external amplifier to 'boost' the signal. From what I was told, the external amplifier did not affect the timing, but we can't rely on it forever. Thus, I was wondering what I could do to improve the timing of this circuit while achieving a larger amplitude? We are hoping to try and achieve a coincidence timing of 300 ps.
The amplitude can be adjusted by adjusting R1 and C1, so I'm not entirely concerned about that. The one thing that I don't really know how to adjust is the speed. My first thought was to switch out the OPA656 for another amplifier with a faster slew rate, but it feels like just swapping it out might not be enough. Obviously, there are other considerations to take into account when picking a new amplifier, but how can I pick a better one taking into account the parameters of the op amp? If we're talking about just the schematic below, putting aside the board layout for now, what else can I do for the timing?
EDIT: My team gave me some values for what they want out of this circuit, so I added them below, and I also adjusted the circuit to showcase the current board schematic. I apologize for not making it clearer, but with the current comments they gave me, I felt it was imperative that I highlight the change.
Currently, our board uses a single set of power supplies (-30 V, +5V, -5V, and GND) to power the entire board. This is shared amongst all SiPMs and op-amps with just one set of decoupling capacitors. For the next design, I'll make sure to power them independently of each other.
We achieved a signal rise time of 6.5 to 9 ns using a 25 ohm resistor. Initially, our feedback resistor was 470 ohms, and while that provided a high gain, it was too slow for our needs. We played around with various feedback resistor values, and we found that 25 ohms gave a really fast time. However, the issue with this value is that the gain is very low, with the max amplitude being around 160 mV, so we needed a second amplification which was done through a NIM module. For my next design, we would like to keep the timing as low as possible while hopefully achieving a 600-850 mV output voltage, a rough gain of 5.5x, so that we can take advantage of the dynamic range of our ADCs. What would be the best way to go about this, keeping the speed the same while increasing gain? Assuming that we power each channel independently in the future, the only other major change I can think of is swapping out the op-amp for another one with faster slew rate and step time.
  • \$\begingroup\$ How identical is each channel? What about if you switch them back and forth? Is there slightly different coax cables linking each channel? 400 ps is about 1/2 foot (15 cm, 6 inches) \$\endgroup\$ Sep 7, 2017 at 18:58
  • \$\begingroup\$ Each channel is identical, with the same parts and values. I don't understand what you mean by switching back and forth. I am not involved with the testing at all, so I don't know anything about the coaxial connectors for each channel. \$\endgroup\$ Sep 7, 2017 at 20:12
  • \$\begingroup\$ Which are your requirements not being met? And what is the difference in sensor position relative to nuclear? energy source. Is it position dependent due to reflections? \$\endgroup\$ Sep 13, 2017 at 19:38
  • \$\begingroup\$ If this is telescopic gamma ray detection, then swap sensors and compare arrival time and adjust cable length to match. Keep in mind Tr~0.35/fBW for 10 to 90% and only use highest quality coax. \$\endgroup\$ Sep 13, 2017 at 20:00
  • \$\begingroup\$ The main requirement that is not being met is the amplitude of the signal. With a feedback resistor of 25 ohms, our times are very fast, yet the amplitude is small due to it. We have been using an external not-on-board amplifier to boost the gain, but this won't always work in the long term, so I'm trying to find a way to balance speed with gain in the output signal. \$\endgroup\$ Sep 14, 2017 at 15:01
5 Answers 5
Don't share the -30V reference for both channels. Instead, duplicate R3 R4 C6 C7 for each channel, this will lower crosstalk.
If you want to measure the delay between both pulses, then both circuits should have identical delays. Since you're down into picoseconds, propagation delay in traces matters. Since FR-4 propagation time varies slightly with temperature, I'd advise having two absolutely identical layouts, with very short traces to the coax connectors.
This will need to be validated by feeding the same pulse of light via matched length fiber optics into the sensors, then checking the delay between recorded pulses. They should be identical. After this, swap the fibers and measure again. Or shine a very fast laser on both sensors simultaneously. Anyway, you get the idea: circuit performance must be validated.
I'm gonna disagree with analogsystemsrf on decoupling: since the inductance of the bondwires inside your opamp is higher than the inductance of a single, well-routed SMD cap, the number of decoupling caps doesn't matter. What matters is that the decoupling cap should be as close as possible to the chip. It should also be large enough to provide all the current needed during the event.
I'd put a 1µF 0805 cap as close as possible, then connect this to the main supply via a 1R resistor. The main supply should have a local cap, like 10µF MLCC.
If you hand solder it, you can stick the decoupling cap really close, closer than pick&place clearances would allow.
Use the SOT23 package, it will have lower inductance.
You could use a faster opamp like LMH6629 OPA847 ADA4895 but of course these are even more finicky about layout.
Must-read links:
http://www.eetimes.com/document.asp?doc_id=1274887
http://mksa.dii.univpm.it/biblioteca/sala_tecnica/scaffale_dispositivi/instr_amp/AN-202.pdf
  • \$\begingroup\$ I second the duplication of the -30V filter components. If you have high rise time events on one photo detector you do not want them to couple to the other circuit. \$\endgroup\$
    – KalleMP
    Sep 12, 2017 at 21:44
  • \$\begingroup\$ Have 100% GND planes under the VDD filtering, to achieve 5X lower inductance of the traces. \$\endgroup\$ Sep 13, 2017 at 17:27
  • \$\begingroup\$ Yeak, 4 layer is better for this, ground plane on lyaer2 is much closer to components and ground inductance much lower... \$\endgroup\$
    – bobflux
    Sep 13, 2017 at 17:42
  • \$\begingroup\$ Why a 1 uF capacitor? TI's recommended layout is 6.8 uF + 0.1 uF capacitors for its power supplies. Also, why 0805? I'm working with 0603 and/or 0402 parts, so why is it necessary to transition to a larger sized part? And thus far, for these photomultiplier boards, I'm working with 6 layer, but I could transition to 4 layer if we're just working with one SiPM. Wouldn't it be more effective if we had some power planes as well rather than all ground planes? \$\endgroup\$ Sep 15, 2017 at 14:00
  • \$\begingroup\$ Smaller (and closer) is better however two low-ESR ceramic caps in parallel can ring, and this will be a problem. In your case, trace inductance will swamp the difference in inductance between a 0402 and a 0805, so the 0402 has relatively little benefit... If you want 2 caps, I'd suggest a 0402 100nF and a 0805 tantalum polymer with lowish ESR like 0.1 ohm, this ensures a very clean, ringing-free decoupling, but is a bit more expensive. \$\endgroup\$
    – bobflux
    Sep 15, 2017 at 14:05
There are a few things that you have to separate here. Timing precision, timing accuracy and rise/fall time. Timing precision tells you how repeatable your timing is over multiple measurements, or how stable it is. Accuracy is about how accurately the timing (delay) through the circuit is defined. And the rise time tells you how fast the signal at the output rises. If I understood you correctly, you are doing difference measurements between the two channels, thus accuracy is not important, as long as the two channels behave the same. Rise/fall time is probably also not important, unless you have high repetition rates. So the only thing you should really care about is timing precision.
That said, 400ps is not that hard, but you are already in the sub-ns region, where all kinds of weird effects pop up. First of all, you have to ensure that noise is kept low. And this also includes the 1/f^a noise (flicker noise and other higher exponent power law noise). In this case, you want the photodiodes to be the limiting elements in the circuit. One general design principle when doing circuits with high timing precision is, that you have to treat your circuit like it was an RF circuit. Ie. if you are after 1ns precision, design it like you are handling a 1GHz signal. Keep it well shielded, in properly specified impedance transmission lines, the power supply has to be low noise and fast reacting, etc pp.
From the description of your photodiodes, especially as you call them photomultipliers, I guess they are actually avalanche photodiodes. There is a large corpus of material on how to reduce their noise. Probably the biggest contributor after temperature is power supply noise. One thing that your simple circuit cannot really do is, keeping the current through the diode constant. Your -30V would have to be really low noise to ensure that your current is stable. Unfortunately, most voltage regulators, especially negative regulators are very noisy. You would do better in redesigning the supply to be a current source instead. This way the amplification (and thus the time it takes to form an avalanche in the diode) can be kept more constant. If this is not enough, you can use a differential circuit, where you emulate the APD by a capacitor of the right size, and thus can subtract the supply noise (this will not reduce the noise due to amplification modulation, though). Also, as peufeu wrote, you want to have one supply per APD. If they are shared, you will inevitably get cross coupling effects. This also includes parallel wires and magnetic coupling! Also keep in mind that APDs are fast switching circuits. You have to treat them like RF devices.
The opamp you have chosen is quite decent, but it has a relatively high 1/f corner frequency of around 10kHz. Unless you really need the high GBW, I would suggest to choose one that is slower, but also has a lower 1/f noise corner frequency. As mentioned above, you do not really care about slew rate, as long as the repetition rate is low. Though, if your slew rate is low, you need to keep it as constant as possible, to keep timing stable. This means that your circuit should be in a temperature stable environment. For your requirement of a few 100ps, an office environment should be sufficiently stable in terms of temperature.
For low noise applications, choose opamps from Analog or Linear. TI, even though cheaper, does not even come close in the performance and quite often their opamps perform worse in real circuits than their datasheets would suggest. Finding the right opamp is quite a bit of work and can easily take a few days to screen all candidates and sort them by their characteristics. The capacitors you have for the opamp are insufficient for the fast opamps you are using. You should use some 10n with a high resonant frequency (that means also as small case as possible) as close as possible to the opamp, followed by 100n and 1u. Do not go leave out the 100n or use 6.8u instead of the 1u. Each capacitor size has its own resonant frequency. If the steps between the sizes are too large, you will build an L-C resonator out of two capacitors. I would not fret too much about decoupling both opamps. Unless your power supply is badly designed you should not see any voltage droop. Putting resistors into the supply lines does theoretically help to decouple, but in practice you can make performance quite a bit worse than by just plain connection. Good capacitor decoupling, with the above mentioned stacking, is important, but anything beyond that should be only done if you have probably cause to believe that supply coupling is indeed the cause of the problems you see (most likely it is not).
As for output amplification, your multiple amplifier stages approach is probably the best. This way you can improve the slew rate step by step without introducing too much noise/jitter. This approach and how to properly design each stage has been documented by Collins. I would not use any external amplifier module as you currently do, as they are not well adapted to your needs. Instead use appropriate opamps or build discrete amplifiers.
One thing that you have not mentioned at all and that affects the performance of the circuit a lot is power supply noise. You need to get to as little noise as possible, as all the power supply noise in the opamps modulate their amplification and thus their slew rate and delay. I recommend using the LT3042 as they have an incredible low noise. There is also a higher current and a negative voltage variant of those, if you need. Before using them, you should read the appnotes carefully. The specs of the LT3042 LDOs is so incredibly good that it's easy to screw them by applying normal good design practices.
  • \$\begingroup\$ Addendum: With a properly designed circuit, it should be possible to get down to 50ps timing precision quite easily. If you want to go further down, you will have to properly analyse the jitter/uncertainty contributions of each component and optimise it appropriately. Getting down to 10ps is likely doable without too much effort. Below that I don't know. I wouldn't be surprised if the circuit can be tuned to deliver a higher timing precision than the instrument you are using for measurements. \$\endgroup\$ Sep 14, 2017 at 1:19
  • \$\begingroup\$ Thanks for your reply. I never worked multiple amplifier stages before, but it seems like doing so would make the timing worse, since the signal would have to travel among two amplifiers. For the capacitors, why are 3 of the needed for the op-amp power supplies? Wouldn't just the 100n and 1u work? \$\endgroup\$ Sep 14, 2017 at 15:20
  • \$\begingroup\$ Don't look at amplifiers like a delay element. Look at them as elements with a noise contribution and see noise as jitter/timing uncertainty. If you can reduce noise by using multiple amplifier stages, then this also will reduce jitter. For the capacitors, see: electronics.stackexchange.com/questions/3879/… \$\endgroup\$ Sep 14, 2017 at 17:13
  • \$\begingroup\$ Thanks for your reply. For the record, due to unfortunate size limitations, I'm using all surface mount parts, using ceramic capacitors, so I may be limited on the available capacitance based on size and temperature coefficient. \$\endgroup\$ Sep 14, 2017 at 21:53
  • \$\begingroup\$ Using SMD is not a bug, it's a feature. It will make your life easier, allow you to use a closed ground plane beneath everything and thus increase shielding. You do not need much capacitance for decoupling. 100n is usually enough. The 1µ is to deliver the energy going into the coax cable. As for tempco, just use X5R and X7R, these are good enough. Choose capacitors that have a high enough voltage rating (capacitance decreases with applied voltage). 100ps precision is really no magic. \$\endgroup\$ Sep 15, 2017 at 15:08
Are your layouts identical ? Are the VDD bypass caps identical? You need substantial Idd, and mismatched power rail impedances will upset the opamp timing. Experiment with dampening the +5V and the -5V rails, using 2 caps in parallel on each rail for each opamp (e.g. EIGHT capacitors of size 0.01uF for the 2 opamps and the 2 rails). In each of the 4 pairs of caps, insert a 1 Ohm Rdampen in 4 places. Dampening is computed as sqrt(L / C); 10nH and 10nF needs 1 ohm Rdampen.
Are your opamp VDD isolated from each other? Install 1--10 ohm resistors from the global power to the local VDDs (4 resistors), and place the resistors right by the opamps. Remember the high frequency PSRR is approximately ZERO. You must provide very clean power to each opamp, and keep them isolated if you want to trust the timing.
Now examine the PSRR curves of the OPA656
This plot does not provide any information out at 1GHz. The trend lines suggest the OpAmp cannot reject trash out at 1GHz. Thus YOU have to design, in the schematic, the filtering and dampening to provide quiet non-ringing power.
  • \$\begingroup\$ The VDD bypass caps are identical, but what do you mean by Idd? The two bypass caps for each power supply for the op-amp is the recommended supply by TI in their datasheet, so that's what I went with. Also, why are the resistors needed? Are you trying to put a low pass filter before each PS? Also, right now, I'm not too focused on the layout; I'm still in the schematic designing stage. \$\endgroup\$ Sep 7, 2017 at 18:01
  • \$\begingroup\$ Sorry, wanted to add on. I understand that layout of the circuit is fundamental, but as we are still designing the schematic, it's not as big of a deal right now as picking the right parts for the circuit. \$\endgroup\$ Sep 8, 2017 at 13:33
  • \$\begingroup\$ Do you understand about the Power pins on the OpAmps being a path to inject trash into the output? At high frequencies, where your 400picoSecond edges occur, your opamp will not reject trash on the +-power pins, because the opamp control loop is not fast enough to monitor and correct the output voltage. YOU must provide a clean quiet +VDD and -VDD. With large transient currents being demanded during the pulse edges, YOU must prevent ringing of the capacitors, and all the various inductors (parasitics: PCB, Cap ESL, etc), thus YOU must dampen by inserting a resistor. \$\endgroup\$ Sep 13, 2017 at 16:44
  • \$\begingroup\$ Insert the value sqrt(L/C) for approximate Q=1 dampening. For 10nH and 10nF, insert 1 ohm. Place 2 caps in parallel right at the OpAmp +VDD pin, and place 1 ohm in series with one of the caps. REPEAT on the -VDD pin. \$\endgroup\$ Sep 13, 2017 at 16:45
  • \$\begingroup\$ You must design the VDD (+, -) bypassing, as part of the schematic. \$\endgroup\$ Sep 13, 2017 at 17:01
I would choose multiple TIA's cascaded specially design to yield greater gain bandwidth resistance or better look at Silicon on Insulator SOI, integration with photo detectors that promises reduced L,C values and ZBW values greater than 30GHz in many R&D areas.
\$ZBW ≈ R_f*BW_{TIA}≈\dfrac{A}{C_{CinT}}\$
Ref: https://www.intechopen.com/books/photodiodes-from-fundamentals-to-applications/design-of-multi-gb-s-monolithically-integrated-photodiodes-and-multi-stage-transimpedance-amplifiers#
Potential sources: http://www.poet-technologies.com/ ( but not likely)
also
  • Have you considered LMH6629 ? –3dB BW of 900 MHz and 1600 V/µs slew rate
    • Supply Voltage Range 2.7 V to 5.5 V
    • Then add a differential amplifier 500 ohm load with 20mA emitter current source and 50 ohm collector load for 20dB more gain. http://www.ti.com/lit/ds/symlink/lmh6629.pdf
    • ultimately you want a rise time < 500ps with ultra low noise and high gain with low input capacitance then get a rise time differential 10% of this.
    • then only use SMA semi-rigid coax to target.
  • \$\begingroup\$ Yes. When boxed in, knock down one or more walls and rethink the situation. \$\endgroup\$ Sep 14, 2017 at 1:06
You absolutely must have the detectors and amplifiers on separate board, otherwise too much high freq coupling.
25 ohm is really too low for the feedback: the output of the opamp may struggle to drive it properly. You can instead use 10..25 ohm current sense resistor followed by low noise voltage amplifier like THS4303.
One can also use RF transformer, or simply 50ohm resistor to match the output of the SiPm to 50 ohm and then use some standard 50 ohm amplifiers ( even AC coupled).
  • \$\begingroup\$ If they're on separate boards, wouldn't you get more noise from them not being connected? I thought SiPM detectors should be put as close as you can to the op-amp in order to reduce the noise. \$\endgroup\$ Dec 3, 2017 at 3:18
  • \$\begingroup\$ I mean detectors and amplifiers of different channels used for coincidence. On each side, however, detector+amplifier indeed should be close. \$\endgroup\$
    – Nikolay
    Jan 5, 2018 at 23:07
