I have a project generated from CubeMX for my STM32Nucleo F303K8. My IDE is SystemWorkbench.
I am using a total of 8 Analog inputs split between two ADC's
ADC1: 1, 2, 4, 12.
ADC2: 1, 2, 3, 4.
I am not sure how to properly read these. I am using DMA and the frequency in which I check the value is much slower than the scan time. But even if it wasn't, I wouldn't care if I read the same value twice.
I just want to have a continuous scan, when one finishes the next starts.
But whatever I try to do, it seems that the only way I can get continuous scans is by manually starting the ADC scans over and over in my main loop using:
HAL_ADC_Start(&hadc1);
HAL_ADC_Start(&hadc2);
or the _IT
variant.
I have tried enabling continuous conversion and then starting the ADC once outside my main loop. But that just does one scan and stops there.
I thought maybe I could just use the scan complete interrupt to restart the scan when it finishes. This works when I restart only one ADC inside the interrupt. However as soon as I add the second to the callback then the system locks up. Obviously there is an interrupt not being handled somewhere.
* @brief Callback when an ADC scan completes.
void HAL_ADC_ConvCpltCallback(ADC_HandleTypeDef* hadc)
if (hadc->Instance == ADC1)
//HAL_ADC_Start_IT(&hadc1);
if (hadc->Instance == ADC2)
//HAL_ADC_Start_IT(&hadc2);
My full code is here: Current commit refid: ef11437
https://github.com/c-herring/Sumo2017_NucleoF303/tree/ef11437f2f21d1beaa2ead0d9f5393c295cf9981
If anyone has any insight for me that would be greatly appreciated.
HAL_ADC_Start_DMA(&hadc1, ADC_buffers.ADC1_Buffer, ADC_BUFFER_LENGTH);
. \$\endgroup\$
