6
Can someone explain this relay pin drawing to me? It is a Releco C5-A30. Why are the contacts labeled twice, bold and not? Can someone explain how they'd wire this for just a simple N/O switch?
screenshot of photo of relay and the relay connection diagram from the datasheet
  • \$\begingroup\$ What do you intend supply to coil AC or DC? and contacts? \$\endgroup\$ – Sunnyskyguy EE75 Sep 8 '17 at 21:23
11
It's not a simple NO switch, it's a three pole dual throw relay switch.
As to the double numbering, the not bold numbers are European standard terminal markings where first digit is the pole, second is a contact codes 1 = common, 2 = NC and 4 = NO. The BOLD numbers are everybody else.
If you look at the socket for it, you will see the same markings.
If you WANT to wire it as a simple single pole NO relay, hook up your coil voltage across A & B, and use either pin pairs 4 & 7, 5 & 8 or 6 & 9 as your switch.
  • \$\begingroup\$ The bold numbers is the pin labeling in the socket to the relay, see "Dimensions [mm]" in the datasheet. \$\endgroup\$ – MatsK Sep 8 '17 at 20:58
  • \$\begingroup\$ That's "three pole, double throw". \$\endgroup\$ – WhatRoughBeast Sep 8 '17 at 23:09
  • \$\begingroup\$ @WhatRoughBeast each pole is a single connection, 3 poles means there are 3 switched being controlled together. Dual throw means a switch with a normally open and normally closed contact. \$\endgroup\$ – ratchet freak Sep 9 '17 at 0:32
  • \$\begingroup\$ @ratchetfreak - conceivably usage has changed, but I'm pretty sure the it's "double", not "dual". The adjective for one is single, the adjective for 2 is double, and for 3 it's triple. for instance, if you google SPDT, you get en.wikipedia.org/wiki/SPDT and there are almost no links to "single pole dual throw". \$\endgroup\$ – WhatRoughBeast Sep 9 '17 at 13:27
  • \$\begingroup\$ @WhatRoughBeast interesting, it was always dual in my neck of the woods, but the meaning is the same I guess. \$\endgroup\$ – Trevor_G Sep 9 '17 at 13:47
