I have placed two additional vias on the thermal pad of the IC. Though the datasheet does not specify thermal holes, but I just did them to connect the pad with the internal ground plane (2nd layer). I am not able to figure out, why altium claims that there is an error and the vias are not connected. Why shall I connect the vias with extra track? Are not they connected through the ground plane? Please help. This happens many times with me.
\$\begingroup\$ Check the via's net \$\endgroup\$– AxisSep 10, 2017 at 5:03
\$\begingroup\$ It's set to GND net \$\endgroup\$– Rakesh MehtaSep 10, 2017 at 5:22
\$\begingroup\$ Are the vias set as "Plated"? \$\endgroup\$– Tom L.Sep 10, 2017 at 7:22
\$\begingroup\$ Yes @TomL. They are marked as plated.. I have added another screenshot \$\endgroup\$– Rakesh MehtaSep 10, 2017 at 7:53
\$\begingroup\$ Not sure, but seems like the vias are not properly connected with Ground Plane (Layer 2) because of the thermal relief cutouts. I am a newbie, so might be wrong :) \$\endgroup\$– Rakesh MehtaSep 10, 2017 at 8:03
1 Answer
That was definitely the Pads were not connecting to the Ground Plane well due to the Thermal Cutouts. I had to disable the cutout by creating a new rule for such Pads and it seems the error is gone now :)
