Image of unknown board with Arduino Nano, the Nano is the blue board despite the label on the black one.
What board is the black one? What is it called? The label says "Nano", but if you look at pictures on the Nano online you can see it's the blue board. I ordered both a while ago from a non-genuine manufacturer and forgot their types. Both work great with the Arduino "IDE" on Nano settings, have ATMega328P. The blue one has a USB-Mini port while the mystery board has a USB Micro like an Android phone or a Wacom tablet.
Sorry if terms are slightly off/inaccurate, I know Stack Exchange can be extremely critical of unfamiliar "newbies".
closed as off-topic by Nick Alexeev Sep 12 '17 at 17:00
  • This question does not appear to be about electronics design within the scope defined in the help center.
If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ It looks like an Arduino Nano and I would expect it to be compatible with the original one. There are many different manufacturers of Arduino boards as the design is open source and very popular. The boards may be var physically but still be compatible from the electrical and programming point of view. \$\endgroup\$ – Kevin White Sep 10 '17 at 17:09
  • \$\begingroup\$ It does look very similar. It seems to have the same components (except for the USB port), only differently-placed. Thanks for the confirmation! \$\endgroup\$ – Shibolet 3 Sep 10 '17 at 17:12
  • 5
    \$\begingroup\$ I'm voting to close this question as off-topic because the information (including a schematic) is readily found by doing a web search on the brand name prominently printed on the board. The issue is not lacking expertise, but that EESE is not a web searching service - it is required to make an attempt and do some personal research before posting a question here. Since the most obvious first research step succeeds here, this should not have been posted. \$\endgroup\$ – Chris Stratton Sep 10 '17 at 17:21
As the silkscreen suggests it is simply called "RobotDyn Nano". You can find more details here by a trivial search: http://robotdyn.com/catalog/boards/nano_v3_ch340g_compatible_with_arduino_nano_v3/
