18
Project: make a power supply that can replace the 240V AC supply shown, so that I don't die when messing with the board that this connects to.
I'm only interested in the part inside the yellow box; the +40V output goes to the power amp section which I'm not working with.
Power supply schematic
So I went out and bought a 7812 and 7815, but then I got confused because of the general consensus that you shouldn't use a 7815 with inverted output pins as a negative voltage regulator, but it seems like that's what they're doing here.
I've ordered a 7915, but my question:
  • (a) Is this circuit doing something smart by connecting the 7815's positive output to ground and using its output as -15V?
  • (b) Is this circuit doing something weird, and I should use the 7915 to source -15V as the gods intended
  • (c) it's impossible to tell, needs more info
Note that I'm sourcing ±30V DC from a preamp circuit in this project, which is higher than what would be at the input in this schematic but well within tolerance for the 7812/7815/7915.
My schematic, using a 7915:
Version with 'reversed' 7815:
  • 7
    \$\begingroup\$ I only had to read the first part to give an upvote. This is a great question, and understanding why the first design works is a big step to a greater understanding of voltage and current flow. \$\endgroup\$
    – pipe
    Commented Sep 11, 2017 at 9:25
    \$\begingroup\$ Your last picture connects the negative pin from the supply to the input of the 7815 rather than the positive one which can't be right. It also has the ground of the 7815 only connected to the output rather than common to both the input and output and that can't be right either. \$\endgroup\$ Commented Sep 11, 2017 at 10:47
  • \$\begingroup\$ @DavidSchwartz do you mean it's an incorrect solution or an incorrect illustration of my question? I'd only want to correct it if it contains errors beyond the scope of the question \$\endgroup\$ Commented Sep 11, 2017 at 11:02
  • \$\begingroup\$ @buildsucceeded Connecting a negative supply output to the input terminal of a positive voltage regulator or not using the ground point as the common point between the input and output are mistakes unrelated to your question. \$\endgroup\$ Commented Sep 11, 2017 at 11:38
    \$\begingroup\$ As already discussed, in other answers: the circuit in yellow only works because the the transformer isolates both parts. Your intended circuit using the 7915 should work correctly, as long as it is not effectively overloading your existing +/30V supply. (Also chaining power supplies like that may result in your +12 and -15 supplies allowing noise to travel back to your +/- 30 volt supply, which may be problematic.) Lastly you are likely to need some fairly significant heat-sinks on these regulators, likely much larger than any heat-sinks in the original circuit design. \$\endgroup\$ Commented Sep 11, 2017 at 15:57
7 Answers 7
19
What you have shown in the yellow box is OK, because the 18 V secondary that's sourcing the 7815 is fully isolated from the other rails. This means the 15 V output is fully floating, and any terminal can be grounded.
If you want to use a centre-tapped transformer (with some slight savings in hardware and diode drops) which produces non-isolated rails, or the non-isolated rails from another piece of equipment, then you need to use 79xx series regulators for the negative rails.
The reversed 7815 you've drawn will not provide the -15 V you want.
  • \$\begingroup\$ Thanks for your answer! Can you expand a little since I am an ultra newb: the 'secondary sourcing' you're referring to is the 18VAC on the right side of the main transformer? \$\endgroup\$ Commented Sep 11, 2017 at 8:52
  • \$\begingroup\$ And in that case, since my ±30V isn't floating, the 7915 would be required for my circuit? \$\endgroup\$ Commented Sep 11, 2017 at 8:52
    \$\begingroup\$ @buildsucceeded updated question to clarify both points. \$\endgroup\$
    – Neil_UK
    Commented Sep 11, 2017 at 8:55
10
Your "reversed" 7815 (last schematic) is incorrect, it cannot work.
Look at the 1st picture, the photo. Note how the 7815 based supply is completely separate from the 7812 one except for the ground connection.
In your 7815 schematic V2 (-30 V) is wrongly connected, it should not connect to ground. It must be floating with respect to ground. Change that and your schematic will be the same as in the photo.
Although the solution as in the photo looks strange, it is OK and will work just like using two lab-supplies to make +12 V and -15 V.
To add to Neil's answer, it is best to think linear regulator as variable resistor (or transistor if you prefer so) between IN and OUT terminals regulated by some "smart" circuit inside. Ground terminal is (mostly) a reference only, not a power terminal. Regulated current flows always (for both positive and negative regulator) between IN and OUT and regulator can control resistance between these two terminals only.
If you take a look on your last schematic, there is V2 generating fixed 30 V voltage between In and OUT terminals of U2 regardless of current through the regulator. Redrawing the regulator as a transistor + error amplifier maybe helps, see below. Your source is connected between IN and OUT while load is between OUT and GND, so you would need load current flowing between IN and GND terminals in order to make things work.
On contrary, situation in the yellow box is different. Voltage source (secondary winding + rectifier) is connected between IN and GND terminals and load is connected to OUT and GND. That is, current from source to load flows through In and OUT terminals of regulator and it can do its job by controlling this current.
You are over complicating this quite a bit!
Remember that voltage is relative! Turn that -15 in to 0 and the gnd in to 15V and the +12 in to 27V and see if it makes sense! What you really have is two stacked voltage regulators The 7812 is using the 7815's output as a voltage reference for it's ground which raises the output by 15 voltages. By treating the middle "tap" as the ground, you can get what appears to be a + and - swing and a negative rail... but note that it really is all floating so there is no ground, it's just that you've chosen a point of reference to be ground and so anything below it will be negative and anything about it will be positive.
If you chose the -15V as ground, then you'd have 0V, 15V and 27V like I said earlier and you've simply design your circuit that way. Of course, your circuitry will have to be reversed to handle the reversed current you through at it but it will all be the same in the end.
The two regulators are exactly the same circuit. But without that connecting, they both are floating! (and simply have 12 and 15 Voltages across the outputs. By connecting the "ground rail"(which isn't 0V, it's just point of reference) of the top one to the "power rail" of the lower one you then just couple them, but the whole combination is still floating.
I think if you just stare at it a bit and realize it's not complicated and that voltage is relative, you'll see what I mean. Remove that coupling leg and then think about it, if you still have trouble.
  • \$\begingroup\$ If I did this, though, I'd have to change the entire circuit that this is meant to be powering, no? \$\endgroup\$ Commented Sep 11, 2017 at 12:33
  • \$\begingroup\$ @buildsucceeded Not sure which change you are talking about. If you mean change the -15V to 0V, then no. Again, voltage is relative. -15V really means it is 15V below the referenced ground, in which ground is considered "0V". Remember, voltage is always between two points. Having a negative voltage is nothing special. It is meaningless. In some cases, the design constrains you in some a way that you can't change how things work but in this case, since everything is floating, we can. \$\endgroup\$
    – Stretto
    Commented Sep 11, 2017 at 12:40
  • \$\begingroup\$ This seems to go against the top two answers, though. Can you explain why? I think that in the original circuit the two regulator circuits float because of the transformer, but in my application I'm feeding them DC so they won't be floating. \$\endgroup\$ Commented Sep 11, 2017 at 12:42
  • \$\begingroup\$ The main point of using negative voltage generators is because we need a true ground that has a very low impedance and this is fixed by the circuit. In this case, the low impedance "ground" is the middle rail but if we don't have a floating system, then it might be fixed and we have to actually create a negative voltage, which is why you see some designs use negative voltage generators. \$\endgroup\$
    – Stretto
  • \$\begingroup\$ They are floating because they are connected to a transformer. The way transformers work is to isolate one system from another by converting the voltage and current in to magnetics then back again. Once you have a system that is floating the voltage is completely relative(and it can be dangerous actually). \$\endgroup\$
    – Stretto
    Commented Sep 11, 2017 at 12:44
Using a voltage regulator upside down is not totally uncommon. This article deals with it in the context of a single voltage source: http://www.edn.com/design/power-management/4458675/Turn-negative-regulator--upside-down--to-create-bipolar-supply-from-single-source
Your circuit does not actually need such a solution because there are two secondary windings which could be used to create a +12V and a -15V supply in the usual way, but maybe the manufacturer of this circuit had 7812 and 7915 regulators already in stock and did not want to add another component type.
This is such a great question, with excellent answers, but I decided to add just a few more details with a simulation:
Two voltage ramps replace the rectifiers for simplicity. The switch connects a 180 ohm load @ 6ms between +9V and -9V.
The transient response is as follows:
Translation:
Please note in the picture with 'reversed' 7815 that this circuit is not correct. The microcircuit will die immediately and kill the power supply.
_____________________________________________
Пожалуйста отметьте на картинке с 'reversed' 7815 что эта схема неправильная. Микросхема сразу умрёт и убьёт источник питания.
  • \$\begingroup\$ Please only post in English on this site \$\endgroup\$ Commented Dec 13, 2018 at 9:20
