I have a 24V pressure switch that is loop powered. Here is the manual/datasheet. I'm trying to figure out how to read the sensor with an Arduino.
Obviously, the Arduino can't handle 24V, so I got some optocouplers (manual/datasheet)
The original schematic looked like this: Original Schematic
This, however, didn't seem to work. When I measured voltage across ports #1 and #2 (from the schematic), it measured between ~13V and ~20V (when the sensor was engaged vs not-engaged).
I'm not really sure how to fix this. I tried using a voltage divider (instead of an optocoupler), but, in my ignorance, I burned up one of my small resisters.
Thanks for any help!
UPDATE: New Schematic (the one above is old) enter image description here
  • \$\begingroup\$ I think that either the output of the optocoupler is not correctly wired (what's DI+ and DI-?) or you accidentally destroyed its LED. To make a test, use a 1-k resistor in series to a 9-V battery, and try to turn ON the LED. Do you see any variation on the rightside of the diagram? \$\endgroup\$
    – next-hack
    Sep 11, 2017 at 21:15
    \$\begingroup\$ So you used the optocoupler without a current-limiting resistor? \$\endgroup\$
    – Mike
    Sep 11, 2017 at 21:21
  • \$\begingroup\$ Are you trying to scale the signal from 24V to 5V? If so, use an op-amp with gain of 1/5. \$\endgroup\$
    – Mike
    Sep 11, 2017 at 21:23
  • \$\begingroup\$ @next-hack, This is actually an older schematic, my bad. In reality, this was for a National Instruments DAQ box, but I changed it to an Arduino. The post has an update of the new schematic. \$\endgroup\$
    – jojoguy10
    Sep 11, 2017 at 21:24
  • \$\begingroup\$ Are you using the NPN or the PNP pressure switch? I think you have to order one or the other. \$\endgroup\$
    – jonk
Here is the final (working) schematic: Final Schematic
In the end, I actually ended up using an NI DAQ box (USB-6255). This would still work with an Arduino though.
Thanks for all the help! Joe
