Below is a MOV varistor:
Does a varistor have anode or cathode or polarity?
Can I connect the legs in any way or does it have an orientation like diode?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityBelow is a MOV varistor:
The best source is the datasheet.
However metal-oxide-varistors are symmetric by construction. Typically a layer of zinc-oxide is sandwiched between two metal plates. There is no polarity.
So you can mount MOVs in any direction.
Other kinds of TVS, such as unipolar TVS diodes do have polarity, and it is typically indicated with a ring, like normal diodes.
