I have built an AC/DC pure sine wave inverter (SPWM). My inverter is a full H-Bridge NMOS (IRF630) setup and the gate is being driven by a 4N37 optocoupler. My input DC signal is 12VDC and this signal is also being used for my optocoupler to fire the gate of my high and low side mosfets. The output of my inverter is the following (Rl=100ohm) Figure 1: Inverter Output no filter
I have designed a low pass LC filter using L=68mH (Inductor 686C) and C=42uF to give me a cut-off frequency of approx. 94Hz. When I connect my filter to the output of my mosfets and connect a 100 ohm load I get the following output waveform.[![Figure 2: Inverter output of Filter][2]][2] I am assuming the the flat spot in my output AC waveform is due to the duty cycle imperfection approaching 100% duty cycle because of the switches not being ideal switches. Now when I connect my probe to check my input signal to my LC Filter expecting it to be similar to the of Figure 1. My oscilloscope now shows that the input signal is now greatly distorted.Figure 3: Input Signal to LC Filter[![Figure 4: Close up of transients][4]][4] It seems to show that the inverter output response has become underdamped when connected to the LC filter. Is this happening due to impedance mismatch between my load and my source? If so how does impedance mismatch lead to an underdamped response? What is a possible approach to creating a matching circuit if this is the case? If not the case, what else is causing this distortion to my input signal? Parasitics of Inductor? Poor Inductor material Selection?? Also, When I disconnect my load the output waveforms seem to be approximately the same.
  • \$\begingroup\$ may not be the issue, but you probably need to add a series resistor to your LC filter, otherwise Q point is pretty high near the cutoff freq. (94Hz). Try 20 Ohms for example and see if it changes anything \$\endgroup\$
    – Big6
    Commented Sep 14, 2017 at 1:54
Thanks Tony. It turned out that my input signal was distorted because of reflections back from my filter creating a standing wave as seen on my oscilloscope. I calculated the input impedance of my LC Filter which was Zin=Zc+Zl which it then turn out to be capacitive at my fundamental frequency. I then built a impedance matching circuit at the output of my inverter H-bridge and this got rid of my input signal reflections!
Your filter input impedance is the problem. That is much lower than the 100 ohm R load, such that peak excursions in the PWM are clipped and the midpoints have shifted as a result.
You need to define both the s11 and s21 response specs or the input Return Loss and transmission loss from loading and also the output impedance of your transformed RdsOn Bridges. Then and only then can you design a filter to meet your specs.
Consider the impedances of source and load at both line and switching frequency in this operation. Then define your impedance requirements so that the no load filter current is minimal <<10% rated current. A different topology is likely needed that raises series impedance above 10kHz while not affecting source impedance at line f.
