A basic question, how does the P-Mosfet reduce the inrush current.
simulate this circuit – Schematic created using CircuitLab Old image link
Can the P-Mosfet's drain and source orientation be swapped along with the diode and would that cause any changes to the protection.
Please help.
http://archive.eetasia.com/www.eetasia.com/ARTICLES/2001JUL/2001JUL03_AMD_POW_TAC.PDF%3FSOURCES%3DDOWNLOAD
    \$\begingroup\$ eek..my eyes... \$\endgroup\$
    – Trevor_G
    Sep 13 '17 at 15:47
    \$\begingroup\$ @Trevor: The image really is that bad in the PDF! \$\endgroup\$
    – Dave Tweed
    Sep 13 '17 at 16:11
Surge is reduced by using a constant current source to charge the Gate capacitance of the P-FET. You can alter the amount of time taken in the linear region by altering the CC drive. If you drive the P-FET with a fast drive (high current therefore fast voltage change) you would get surge current.
No you can't turn the P-Fet around (swap Source and Drain) since you'd have simply a (body) diode which would conduct and drop the source voltage.
  • \$\begingroup\$ Thanks for the answer, can we connect the gate directly to the ground instead of CC circuitry? Would that help in reducing the inrush current? \$\endgroup\$
    – SIllyMan
    Sep 13 '17 at 16:15
  • \$\begingroup\$ No, that would defeat the surge protection. Read the note you reference .....this is slew rate control of a FET turn-on. \$\endgroup\$ Sep 13 '17 at 16:18
As Trevor says, that's not a nice image to look at!
Quick answer to your question though: the FET slowly turns on, basically acting as a resistor that reduces in value. High resistance at the start reducing the high currents when you pretty much have a short to ground as the capacitor is empty. The FET turns on, reducing resistance as the voltage of the cap increases to match the source voltage.
It should be obvious that if you swap drain and source, the body diode will no longer block the inrush current.
