I was design POE+ circuit , so I read lot of articles on
POE(power over Ethernet) IEEE802.af 15.4W on PSE side , For 10/100 base T can use Alternative A method where it use to deliverer power on data pair or can use Alternative B method where it use to deliverer power on data pair. And for 10/100/1000 base T it uses all four data pair to deliver the power.
Also
POE+(power over Ethernet) IEEE802.at 30W on PSE side , For 10/100 can use Alternative A method where it use to deliverer power on data pair or can use Alternative B method where it use to deliverer power on data pair. And for 10/100/1000 base T it uses all four data pair to deliver the power.
And
UPOE/POE++ IEEE802.bt 60W on PSE side , For 10/100 and for 10/100/1000 base T it uses all four data pair to deliver the power.
I am little bit in need od some solid explanation what make to possible to deliver power on data pair and its not corrupting the data, since POE power voltage is 48V and data voltage is 3.3V. how two different level of voltage sharing the same line.
My understanding is Center tapped transformer play a key role here, and data is in differential mode and power will be in common mode. And power is on 0 Hz and data is on couple in Mhz. different frequency band.
but how , whats the logic, magic behind this.
I am thinking same concept can be used for RS485, CAN , USB or any differential line by using a Transformer. ( understand also need same type of PD at opposite end)
