I need to design a +/-1.5A, 3kHz small-signal-bandwidth (absolute min, for 3° max phase and 1% max error on amplitude) current controller for a 20 Ohm 0.1H load with a +/-100V supply rail (the current setpoint profile I'm planning to request should make the load swing +/-80V).
I want to make that controller based on a high power op-amp (because I need very good smoothness so no H-bridge) from PowerAmp Design, the PAD129. It has in particular a GBW of 1MHz and a correct SOA for this application. The opamp controls the voltage across a sense resistor capable of dissipating the heat.
Here is the best of my many attempts using the manufacturer's SPICE model of the opamp, and yet it still does not work. I've also tried placing the RC between the output of the opamp and the negative input, with similar results. enter image description here
I have calculated the transfer function and plotted it considering the opamp to have a finite gain equal to a first order with DC gain of 1 million and rolloff frequency of 5Hz, and I have noticed that the feedback network has very little impact on this resonance: enter image description here
So it seems the inductor is resonating with something, but I don't see how to damp it enough to increase the gain-limited bandwidth (the phase-limited bandwidth is more or less what I need).
And finally, I thought the wobble on the waveform above was due to that resonance, but how can a pure sine input result in an output waveform with a different frequency, since the opamp is supposed to be linear (the output voltage is not clipped)?
Do you have an idea of how to modify the circuit to make it work? I'm out of ideas.
Edit: Suggestion of peufeu (and one of my previous attempts). This is the furthest I can push the resonance, and it still isn't enough. enter image description here
  • \$\begingroup\$ I can't see the circuit well, but why did you place the feedback across the inductor? Where is the load 200 ohm and 0.1H? What are all other resistors? It would be easier to see frequency rather than rad/s. \$\endgroup\$ Commented Sep 13, 2017 at 21:22
  • \$\begingroup\$ 0.1H and 200ohm at 3kHz from my calc gives 2k ohm impedance. Injecting 1.5A would need approx 3kV. \$\endgroup\$ Commented Sep 13, 2017 at 21:46
  • \$\begingroup\$ Can't believe I had forgotten this. Oops. \$\endgroup\$
    – bobflux
    Commented Sep 13, 2017 at 21:48
  • \$\begingroup\$ Marko Bursic: I've tried several forms of feedbacks, this is one of them :/ The load is just at the output of the opamp, and the resistor on the right is the current sense resistor. 1.5A is not injected at 3kHz, I only need this bandwidth for small signals. \$\endgroup\$ Commented Sep 13, 2017 at 21:58
  • \$\begingroup\$ +1 for "damp"! (rather than "dampen", which means to make something wet) \$\endgroup\$
    – Dave Tweed
    Commented Sep 14, 2017 at 0:39
The opamp is oscillating...
This is due to the feedback inductor current, which has 90° phase lag relative to output voltage. Since the opamp's output already has about 90° phase lag relative to input voltage, you get 180° lag and it oscillates.
"I have no idea what I'm doing" method:
The 20R resistor on the output is part of the load?
Remove the top series RC (can't see the part names on your schematic) and add a cap from the output of the opamp to the negative input, perhaps 100pF. Adjust its value until the frequency response looks good, you should get rid of the peak.
Engineering method:
Learn about bode's stability criterion. (VF)
Now, plot the open loop gain by breaking the loop and inserting a source inside:
http://www.linear.com/solutions/4449
Then do the above capacitor trick...
Then close the loop, it should work.
  • \$\begingroup\$ Still, I don't see how the control input voltage will translate into current setpoint. The OP talks about current controller. \$\endgroup\$ Commented Sep 13, 2017 at 21:42
  • \$\begingroup\$ Yeah he wants to control the current in the inductor, so he takes feedback on the 3R resistor which gives an image of the current... \$\endgroup\$
    – bobflux
    Commented Sep 13, 2017 at 21:44
  • \$\begingroup\$ Thanks for the answer peufeu. You'll recognize the same problem as the last one we discussed :) I've also tried with a capacitor between opamp out and V-, with similar results... \$\endgroup\$ Commented Sep 13, 2017 at 22:00
  • \$\begingroup\$ try stepping the cap value 100pF - 10nF or something... \$\endgroup\$
    – bobflux
    Commented Sep 13, 2017 at 22:08
  • \$\begingroup\$ See edit in my question, I've tried 1pF to 100nF (and various resistances), the lower cap the better and 1pF doesn't cut it :/ \$\endgroup\$ Commented Sep 13, 2017 at 22:10
