we start to deal with wireless charging technology in recent years with the booming of smart phones why wasn't it possible with laptops? does the smart phone's battery differ from laptop's?
closed as primarily opinion-based by tomnexus, PeterJ, Dmitry Grigoryev, DerStrom8, laptop2d Sep 15 '17 at 1:04
Many good questions generate some degree of opinion based on expert experience, but answers to this question will tend to be almost entirely based on opinions, rather than facts, references, or specific expertise. If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ Take a look at existing wireless charging reference designs, in particular the wattage and typical efficiencies. Then take a look at the specs of your laptop charger. It's not impossible, but laptops require quite a bit of power to charge quickly. A netbook, maybe... \$\endgroup\$ – uint128_t Sep 14 '17 at 2:24
  • \$\begingroup\$ Who said it can't? \$\endgroup\$ – Bort Sep 14 '17 at 2:38
    \$\begingroup\$ It's actually cheaper and in almost every way better to use a docking station. Even for phones I still believe it's better to use a docking station, also in almost every way. \$\endgroup\$ – user3528438 Sep 14 '17 at 2:45
  • \$\begingroup\$ Who said they don't? \$\endgroup\$ – Dmitry Grigoryev Sep 14 '17 at 11:34
  • \$\begingroup\$ It's not a matter of not being possible, it's a matter of not being practical or not being cost-effective. Watch Dave Jones' EEVblog videos about UBeam. \$\endgroup\$ – DerStrom8 Sep 14 '17 at 14:47
You can use wireless charging techniques for charging laptop computers but you won't be very happy with the current state of the technology.
The wireless charging systems that I've worked with for smartphones are good for maybe 10 Watts (but often less). That's okay for a smartphone and most will reach full charge in a few hours.
The smallest laptop charger for a medium-sized laptop is at 60 Watts. Higher-end laptops can have chargers rated at 135 Watts or more.
Many (most?) laptops need 20 to 50 Watts just to operate. Your little 10 Watt wireless charger can't even keep up with required power to operate the laptop, let alone have enough energy for charging the battery.
To charge a laptop, well technology wise it's not a problem. But wireless charging have some disadvantages that inflict on the usage, like:
Ref.: https://en.wikipedia.org/wiki/Inductive_charging
Slower charging – Due to the lower efficiency, devices take longer to charge when supplied power is the same amount.
More expensive – Inductive charging also requires drive electronics and coils in both device and charger, increasing the complexity and cost of manufacturing.
Inconvenience - When a mobile device is connected to a cable, it can be moved around (albeit in a limited range) and operated while charging. In most implementations of inductive charging, the mobile device must be left on a pad to charge, and thus can't be moved around or easily operated while charging.
