I'm in mood to put together my own quadrocopter. Just before I ordered parts wanted to some experts to tell me if configuration if compatible enough. Or maybe you have better suggestions for this motors? Actually i'm not shure about battery. Will it handle this 4 motors? So I put in my cart:
ZIPPY Flightmax 4000mAh 3S1P 20C
Capacity: 4000mAh
Voltage: 3S1P / 3 Cell / 11.1v
Discharge: 20C Constant / 30C Burst
Weight: 306g (including wire, plug & shrink wrap)
Dimensions: 146x51x22mm
Balance Plug: JST-XH
NX-4008-620kv Brushless Quadcopter Motor
Kv: 620rpm/v
Turns: 16T
Resistance: 0.129Rm
Idle Current: 0.8A
Can size: 45mm
Can Length: 14mm
Shaft: 3mm (Includes Prop saver mount for GWS style props)
Suggested ESC: 30A
Rated Watts: 180W
Weight: 79g
Cell count: 3~4S Lipoly
TURNIGY Plush 30amp Speed Controller
Cont Current: 30A
Burst Current: 40A
BEC Mode: Linear
BEC : 5v / 2A
Lipo Cells: 2-4
NiMH : 5-12
Weight: 25g
