I just bought a PICKit3 and Linux finds it:
$ lsusb
Bus 003 Device 081: ID 04d8:900a Microchip Technology, Inc. PICkit3
But MPLABX doesn't recognize it (see image, the SN-foldout is unavailable). I just re-installed v4.01 but the issue remains. I tried run MPLAB as root to see if it was a permission issue, but the error is for root as well.
I tried MPLABX under Windows, and it recognized the PICKit3 immediately. I am not, however, going to develop things under Windows.
Does the Linux-version of MPLABX require some special configuration? I am running 64-bit Debian 7.3 (according to /etc/debian_version).
  • \$\begingroup\$ I had no problems using it in Linux. I see that reinstalling doesn't help - so you might need to go to Microchip support. \$\endgroup\$
    – Reinderien
    Commented Sep 15, 2017 at 13:33
  • \$\begingroup\$ ..."I just re-installed v4.01 but the issue remains." \$\endgroup\$
    – bos
    Commented Sep 15, 2017 at 13:34
  • \$\begingroup\$ Yes, I saw that and edited my comment. \$\endgroup\$
    – Reinderien
    Commented Sep 15, 2017 at 13:35
  • 6
    \$\begingroup\$ Did you add the appropriate udev rules so that it can be accessed by user processes? \$\endgroup\$ Commented Sep 15, 2017 at 16:22
    \$\begingroup\$ No rebooting required. You can reload the rules with udevadm: "udevadm control --reload" \$\endgroup\$
    – Ayhan
    Commented Sep 15, 2017 at 20:21
The problem was that I was using a too old glibc-version for the MPLABCOMM-libs. Upgrading the glibc solved everything.
  • \$\begingroup\$ wow, im really surprised that you got it working under Linux. Did you buy the XC8 compiler for linux as well? \$\endgroup\$
    – Abel Tom
    Commented Jul 12, 2018 at 5:07
    \$\begingroup\$ No, I use the free version. \$\endgroup\$
    – bos
    Commented Jul 12, 2018 at 13:20
Recently I updated glibc-xxx, but the problem still persists. Now i'm trying with this way, from microchipdeveloper.com mplabx:installation#step9
For Linux distributions that use systemd, the systemd-udevd unit may be setup to avoid inter-process communications via sockets for security reasons. Recently Ubuntu 18.04LTS has been shipped in this way. This is a change from 17.10. Other distributions like Manjaro are also shipped with blocked inter--process communications via systemd. MPLAB X IPE and IDE rely on the systemd--udevd unit for plug and play. MPLAB X software has udev rules that allow a program to run on plug-and-play notifications. This program relies on sockets to communicate with MPLAB X IDE and IPE. So, to have working plug-and-play in MPLAB X software, you need to re-enable socket communications.
You can do this by adding an override file for systemd-udevd. ​
$ sudo systemctl edit systemd-udevd
This will open an editor and will create an override.conf file. In the override file, include the following lines: ​
[Service]
IPAddressAllow=localhost
Then re-start the service: ​
$ sudo systemctl daemon-reload
Finally check the override.conf has been loaded: ​
$ sudo systemctl status systemd-udevd
● systemd-udevd.service - udev Kernel Device Manager
Loaded: loaded (/lib/systemd/system/systemd-udevd.service; static; vendor preset: enabled)
Drop-In: /etc/systemd/system/systemd-udevd.service.d
           └─override.conf
IN MY CASE :
> Loaded: loaded (/usr/lib/systemd/system/systemd-udevd.service; static;
> vendor preset: disabled)
jul 11 22:00:53 localhost.localdomain systemd-udevd[2757]: Process
> '/etc/.mplab_ide/mchplinusbdevice add' failed with exit code 250.
  • \$\begingroup\$ Hi - Thanks for this info. It's not clear to me exactly what you mean by "Now i'm trying whint this way". At the end of the text you copied from microchipdeveloper.com/mplabx:installation#step9 (some of which is unfortunately incomplete and needs fixing) you seem to be reporting an error message. So my questions are: (a) Have you actually successfully followed those steps and this is an answer? (In which case, why are you reporting an error?) Or do you have problems, and this is a question that's in the wrong place? (b) Will you be fixing the problems with the copied text? \$\endgroup\$
    – SamGibson
    Commented Jul 12, 2018 at 3:56
  • \$\begingroup\$ Hi, (a) The PICKIT3 is completely functional following those steps. (b) the reporting error message still persist, but not seem affect the pickit3 functions. \$\endgroup\$ Commented Jul 13, 2018 at 17:36
