I am making a new design which I use a 4S 18650 batteries with total voltage of 14.8V
in my design I need to have 9V and 5V using 7809 and 7805 regulators
are these regulators going to overheat ?
here is a schematic of my design
Schematic
  • 4
    \$\begingroup\$ what is the load you are going to be driving with that? \$\endgroup\$ Sep 15, 2017 at 14:37
  • \$\begingroup\$ will I am making an arduino extension .. so basically arduino + DC motors + Servo Motors + Sensors maximum current by these parts is around less than 1A in total \$\endgroup\$
    – ihsanogluu
    Sep 15, 2017 at 14:38
    \$\begingroup\$ A linear reg is a self regulating resistor. The voltage dropped over it multiplied with the current through it will be the power dissipation. \$\endgroup\$ Sep 15, 2017 at 14:45
    \$\begingroup\$ You'll get better battery life with switching regulators... \$\endgroup\$
    – bobflux
    Sep 15, 2017 at 14:46
  • \$\begingroup\$ -1 for not including any of the information that we'd need to actually answer the question, even after being asked. Please edit the question to include the necessary information. \$\endgroup\$
    – The Photon
    Sep 15, 2017 at 16:03
1 amp from a 5 volt linear regulator fed with a supply of 14.8 volts quite simply means the power dissipated by the device will be 1 x 9.8 volts = 9.8 watts. Power dissipation in the device is defined by the volt drop across it (9.8 volts) and the 1 amp flowing through it.
I'd definitely consider a switching regulator - power efficiency is going to be about 90% so, with 5 watts out, there will be about 5.5 watts in and, from a 14.8 volt supply this means it will take a current of about 375 mA i.e. a lot smaller drain on your battery.
  • \$\begingroup\$ 1A will be pulled from the 9V regulator only .. the 5V regulator is used for sensors and low current applications.. \$\endgroup\$
    – ihsanogluu
    Sep 15, 2017 at 14:48
  • \$\begingroup\$ thank you for your comment I would really appreciate it if you write a switching regulator name like 7805 \$\endgroup\$
    – ihsanogluu
    Sep 15, 2017 at 14:50
  • \$\begingroup\$ There are plenty - both Linear technology and TI have good offerings and both have selection tables that will help you decide. You pick one and tell me and I'll take a look but please embed the link to the data sheet. \$\endgroup\$
    Sep 15, 2017 at 15:17
  • \$\begingroup\$ thank you for your effort ... I will try to find one and make a schematic according to its datasheet and show it to you afterward. \$\endgroup\$
    – ihsanogluu
    Sep 16, 2017 at 11:00
That is 5.8W of heat to dissipate in U1. The L7809ABD2T that you are using is a surface mount part with a practical power limit of around 1W. Therefore it will overheat, badly. If you are to use a linear regulator you need to use the TO-220 part (L7809ABV) with a small heatsink. The better solution is to use a small DC-DC switching regulator which is far more efficient, will dissipate far less heat and use less battery power. If you like ST parts try a L5973A.
You may be OK using the L7805ACD2T for the 5V supply so long as you draw less than 100mA.
Assuming this is a hobby one-off, suggest you use an adjustable LM2596-based module for the 9V 1A supply and hang an LM7805 off the 9V input for the low current 5V supply. You can get 150mA @5V without a heatsink conservatively.
You could also consider replacing that series diode with a MOSFET to reduce the voltage drop for reverse-voltage protection.
