Some devices output differential outputs since both wires carry varying signals which are mirrored. Most devices on the other hand output one signal carrying and one GND wire. There is also differential-ended wiring and single-ended wiring. My question will be about "external" interference type of noise(EMI or RFI or maybe capacitive coupling) impinging upon both wires.
After some reading, if I'm not wrong I came to understand the fact that what we really want is "the same noise should appear upon each line" regardless of it is a differential or single ended wiring. And the noise must be common(common mode) so that the differential amplifier can cancel it out.
As far as I understand, there are two main ways to make the noise common. One of them is twisted pairing. The idea here is the wires are very close to each other because they are twisted and the same magnetic filed or electric field hits upon both wires. The second method to make the external noise common is to make the total output impedance(from source to receiving end) of both wires equal, so if an EMI happens both wires would induce the same voltage at the same time.
Upto here was just a summary of my understanding to show/check to whom read this.
Here is a simple illustration of a single-ended and a differential-ended wiring:
If they are both using twisted wiring and they are all balanced, they would both reject the common mode noise.
So what is the point to send the signals in mirrored fashion if one can balance and twist a single-ended wiring as well? Is that because something is practically easy to establish in differential/mirrored outputs? I really couldn't find a good answer to this.
edit illustration for a comment:
