We need to make a logic circuit, the given function is:
f= (AB) + (not(C)) + (not(A)D)
I already tried a bit, and I can manage to make a circuit with 7 NAND gates but not with less... Could anyone help me with that, please? I also added a 3 NAND input gate, which is not allowed...
    \$\begingroup\$ Then at least show what you have and how you got there. Use the schematic entry tool to draw the schematic of your solution. \$\endgroup\$ Sep 17, 2017 at 12:26
  • \$\begingroup\$ Did you apply all the Rules of Logic? ( e.g. distributive) \$\endgroup\$ Sep 17, 2017 at 12:28
  • \$\begingroup\$ Have you studied combinational logic design. covering logic minimisation, De Morgan's rules, and Karnaugh mapping? Have you tried any of them here? \$\endgroup\$
    – user16324
    Sep 17, 2017 at 12:58
  • \$\begingroup\$ Brian, I tried , but I just can't figure it out ... \$\endgroup\$
    – Maarten
    Sep 17, 2017 at 13:04
    \$\begingroup\$ Your example circuit can't work. That final 3-in NAND is the same as an OR gate with inverted inputs, so I don't think you are ORing in not-C there (in fact, the whole thing looks wrong to me on its face.) \$\endgroup\$
    – jonk
    Sep 17, 2017 at 14:26
I take it that this is early in a class and that you've not yet been taught enough logic manipulation to be able to rigorously develop a desired result here.
Let me start with something quite simple. A NAND is the exact same thing as an OR, with inverted inputs. You can work this out for yourself once you know De Morgan's two laws:
  1. the negation of a disjunction is the conjunction of the negations.
  2. the negation of a conjunction is the disjunction of the negations.
So: \$F_0=\overline{X\cdot Y}=\overline{X}+\overline{Y}\$. Handy to know.
From the above, now:
$$\begin{align*} \overline{X\cdot Y}&=\overline{C} + \left(A\cdot B + \overline{A}\cdot D\right)\\\\ &=\overline{\overline{\overline{C} + \left(A\cdot B + \overline{A}\cdot D\right)}}\\\\ &=\overline{C\cdot\overline{A\cdot B + \overline{A}\cdot D}}\\\\ & & \therefore X &= C\\\\ & & Y&=\overline{A\cdot B + \overline{A}\cdot D} \end{align*}$$
So that is one NAND, as follows:
The problem has been reduced. Continue, by focusing on the remaining unresolved portion:
$$\begin{align*} \overline{X\cdot Y}&=\overline{A\cdot B + \overline{A}\cdot D}\\\\ &=\overline{\overline{\overline{A\cdot B + \overline{A}\cdot D}}}\\\\ &=\overline{\overline{\overline{A\cdot B}\:\cdot\:\overline{\overline{A}\cdot D}}}\\\\ & & \therefore X &= \overline{A\cdot B}\\\\ & & Y&=\overline{\overline{A}\cdot D} \end{align*}$$
Clearly, the double-negation we are left with means we need to invert the output of the NAND (to make an AND.) So now:
Then quickly:
Now, the remainder is also obvious:
$$\begin{align*} \overline{X\cdot Y}&=\overline{\overline{A}\cdot D}\\\\ & & \therefore X &= \overline{A}\\\\ & & Y&=D \end{align*}$$
So:
Now, this process works. And it can work for fairly complex expressions, too. But it won't necessarily find optimal solutions. There are methods to help with that process.
  • \$\begingroup\$ Thanks! Definitely a good documentation for the community! \$\endgroup\$
    – Maarten
    Sep 29, 2017 at 7:35
Here is the circuit made using Quine–McCluskey algorithm which is functionally identical to Karnaugh map. Function mapped using the tool below.
P.S. You may find this useful https://sontrak.com/
  • \$\begingroup\$ Looks like that is straight out of Logic Friday's logic diagram display generator, too. \$\endgroup\$
    – jonk
    Sep 17, 2017 at 15:13
  • \$\begingroup\$ Yes it's made with that tool which implements it \$\endgroup\$
    – Knight
    Sep 17, 2017 at 15:15
