Implementing a 4-tap FIR unity coefficients, is this code efficient in power and area ?
always@(posedge Clk)
begin
  //unit delays using flip flops
  xn0<=Xin; //x[n]
  xn1<=xn0; //x[n-1]
  xn2<=xn1; //x[n-2]
  xn3<=xn2; //x[n-3]
  add0<=xn0+xn1;
  add1<=xn2+xn3;
  add_all<=add01+add23
  Yout<=add_all;
end//aways
    \$\begingroup\$ Are you okay with only getting the output 4 cycles after the inputs? What I mean is this filter is giving \$y[n] = x[n-4] + x[n-5] + x[n-6] + x[n-7]\$ (if I calculated correctly). Is that the filter you want? Because often we want the output to depend on the most recent inputs available. But other times a delay may be acceptable to save power or area. \$\endgroup\$ – The Photon Sep 18 '17 at 15:02
  • \$\begingroup\$ No I want x[n]+x[n-1]+x[n-2]+x[n-3] \$\endgroup\$ – Adigh Sep 18 '17 at 21:17
Do it in following
   assign add01   = xn0+xn1;
   assign add23   = xn2+xn3;
   assign add_all = add01+add23;
   assign Yout    = add_all;
   always @ (posedge Clk or negedge reset_n)
   begin
     if(~reset_n)
     begin
       xn0  <= 'd0
       xn1  <= 'd0
      xn2  <= 'd0
   xn3  <= 'd0
   Yout <= 'd0
 end
 else
 begin
   xn0    <=Xin; //x[n]
   xn1    <=xn0; //x[n-1]
   xn2    <=xn1; //x[n-2]
   xn3    <=xn2; //x[n-3]
 end
end //always
You are creating additional pipeline steps for the intermediates. This introduces an additional delay, as The Photon suggested in the comments, and the output is \$x[n-7] + x[n-6] + x[n-5] + x[n-4]\$.
The additional pipeline steps can give you a higher \$f_{max}\$, but that is probably not what you want.
The minimum delay variant \$x[n-3] + x[n-2] + x[n-1] + x[n]\$ is more complex, because it would end in a combinatorial stage, and adding more combinatorial outputs would reduce \$f_{max}\$. That stage would have
assign Yout = Xin + xn1 + xn2 + xn3;
to calculate the output, and
always @ (posedge Clk)
begin
    xn1 <= Xin;
    xn2 <= xn1;
    xn3 <= xn2;
end
You see that there is no register stage for xn0 here, because that is part of the component feeding Xin, which is expected to be synchronous to Clk as well.
A one-clock delay compromise would be
assign Yout = xn0 + xn1 + xn2 + xn3;
begin
    xn0 <= Xin;
    xn1 <= xn0;
    xn2 <= xn1;
    xn3 <= xn2;
end
This reduces routing complexity at the cost of one cycle delay. Whether that is a good trade-off is an engineering decision.
