I am driving a blue led with a pnp transistor as schematic1.I am trying to bypass the transistor without removing it as schematic2.Is it OK?
schematic1 Schematic1 schematic2 Schematic2
Yes you can do like Schematic 2. The LED will light till the battery wears down.
  • \$\begingroup\$ What about the transistor? \$\endgroup\$ Commented Sep 19, 2017 at 1:08
  • \$\begingroup\$ If only one leg of the transistor is connected and the rest is hanging in the air it does nothing. You could clip it out if you wanted to. \$\endgroup\$ Commented Sep 19, 2017 at 1:16
  • \$\begingroup\$ When measuring voltage on emitter or base pin with multimeter,why am i reading voltage on these pins? \$\endgroup\$ Commented Sep 19, 2017 at 1:22
  • \$\begingroup\$ Because when you connect the meter to those parts that are hanging in mid air you are changing the circuit. Your meter is not a purely passive device and it adds some resistance according to its input impedance. That causes some current to flow leaking through the transistor and/or the resistor. \$\endgroup\$ Commented Sep 19, 2017 at 1:30
  • \$\begingroup\$ If so, is it impossible to see practically if voltage available on pins which are hanging in mid air? \$\endgroup\$ Commented Sep 19, 2017 at 1:34
