I have a project that has 48 various lengths of WS2812B RGB tape strips. All 12V.
Here is a link to the tape i am using. datasheet
I seem to have a lot of flickering at the ends and the occasional flash or artifact when running animations.
I am not sure what the issue is, i cant tell if it is voltage or signal. What can i do to determine where the problem is?
Does this sound like common issues with this tape? Thanks,
    \$\begingroup\$ Dont cascade them all. Stick to one 5m and then feed in parallel or use dual power injection for 9m \$\endgroup\$ Sep 20 '17 at 4:50
    \$\begingroup\$ Power should be injected ever few metres. \$\endgroup\$
    – Passerby
    Sep 20 '17 at 4:51
  • \$\begingroup\$ None of my strips are over 4.2M and I have 8 of them on a 600w power supply (HLG-600) all run parallel. Total watts used per power supply is 455watts per PS. \$\endgroup\$
    – jt3
    Sep 20 '17 at 12:41
    \$\begingroup\$ The voltage is too low at the end of the strip. \$\endgroup\$
    – user253751
    Jan 17 '18 at 4:34
  • \$\begingroup\$ Have you connected the ground of the Arduino/Micro-controller to the ground of power supply ?. I had the same flickering issue when i forgot to do the same. \$\endgroup\$ Jun 30 '20 at 15:59
Confirmed. I had a similar flickering issue with 5V addressable LEDs with about 2.5-3 meters of cable. Even if the all connections were insulated, holding the LED strip in my hand provided a lot of capacity through the ground connection to eliminate the RF noise. So adding one simple ferrite clamp solved this issue instantly.
Is the supply with specs at middle, ends and have you not exceeded the Run length table?.
If V+ is in spec, you may be getting interference on data lines from something. Any clues?
If you have a ferrite clamp to put around cable,or you can earth ground the source (laptop? or supply) , this will help greatly reduce CM noise interference, which is a common problem for high speed Serial data on long cables with high impedance.
Ensure data ground and supply ground are well connected.
  • \$\begingroup\$ I have the supply at one end, but I dont know if I exceed the run length. The manufacturer does not have a table, is there a standard one on line somewhere? I could be getting interference, but i am not sure what to do about it or how to confirm that I am. What would the results look like if I were out of spec on the voltage? \$\endgroup\$
    – jt3
    Sep 20 '17 at 12:09
  • \$\begingroup\$ your link has the datasheet with run length limits. How long is it? what colour? \$\endgroup\$ Sep 20 '17 at 13:18
  • \$\begingroup\$ None are longer than 4.2 meters and they are RGB \$\endgroup\$
    – jt3
    Sep 20 '17 at 13:50
