I am looking to make a simple circuit where i want to measure a freezer's temperature at -80 C. The problem is that most NTC thermistors i see have a low range of about -40 C. Is there a trick in designing the voltage divider to capture only low temperatures. I would accept an error of +-10C.
I would like to use a cheap thermistor if possible
