Two questions: I thought that a resistor network/array was just a combination of resistors together. Is there anything more to it? This question distinguished a resistor network vs a bunch of discrete resistors: Pros and cons of using resistor networks over individual resistors?
Why don't you combine all the resistors together into one resistor?
  • 6
    \$\begingroup\$ Why the linked question is not answering yours? \$\endgroup\$
    – Eugene Sh.
    Sep 21, 2017 at 16:54
  • \$\begingroup\$ You're going to have to show an example where they are not already combined. \$\endgroup\$
    – Trevor_G
  • 5
    \$\begingroup\$ Resistor networks are multiple resistors, yes, but they are not all just wired in parallel or series - i.e. it is not a 2-pin device, it has multiple individual resistors (though sometimes one pin is common to all). \$\endgroup\$ Sep 21, 2017 at 17:01
  • \$\begingroup\$ @EugeneSh. Why would it be answering my question? It says individual resistorS. Not replacing all resistors with one. \$\endgroup\$ Sep 21, 2017 at 20:12
    \$\begingroup\$ If you only want one resistor, buy one resistor. A resistor array is used when you need more than one resistor \$\endgroup\$
    – sstobbe
    Sep 21, 2017 at 23:33
One common use of a resistor network is to pull multiple lines up or down, e.g. on a data bus:
Replacing the resistor network with a single resistor would short all of the lines in the bus together, making it not work at all:
    \$\begingroup\$ That's not a situation I'm looking at. I'm looking at a situation where they can all be combined and be equivalent theoretically. \$\endgroup\$ Sep 21, 2017 at 20:08
  • 6
    \$\begingroup\$ @Goldname Then you need to give some details about your situation in the question. \$\endgroup\$
    – user39382
    Sep 21, 2017 at 20:32
For long run machine assembly placement of a component costs 3-4 cents. A resistor and an array cost sub cent. So one network saves about 10 cents. It may become difference of tens of thousands of dollars for serial production.
The main advantage of resistor networks is space and time. When using the same value resistor multiple times, as in pull up resistors on a micro processor buss. Placing 1 component that has say 8 resistors in it with no space between them,it saves space and also saves the effort of placing multiple components with just 1. They are never connected together except on one side, to go to Gnd for pull down or Vcc for pull up. The other type does not connect the resistors at all, for address lines that need series resistors for example.
