I have doubt about beta of feedback loop of inverting amplifier.
The expression for the feedback gain is :
$$A_{cl} =\frac{A}{1 + A \cdot \beta}$$
what is value of beta here? and how do I reach to final expression
$$A_{cl} =\frac{R_f}{R_in}$$
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityI have doubt about beta of feedback loop of inverting amplifier.
The circuit is not exactly equivalent to the two blocks. Some steps must be taken before arriving to that formula.
\$\beta\$ in fact is not \$R_{in}/R_{f}\$.
It is \$R_{in}/(R_{in}+R_f)\$ instead. Which is the same as the non inverting configuration.
Removing the internal summing node (notice that the signs are brought to the external one!) you get:
(Then if you want you can bring the first block inside the loop, but \$A_{OL}(s) \cdot \beta\$ does not change. And that's the term you'll be considering to analyze the stability of the closed loop system).
If \$A_{OL} = \infty\$, then you get:
$$ A_{CL}=-\frac {R_{f}}{R_{in}+R_{f}} \cdot \beta^{-1} = - \frac {R_{f}}{R_{in}} $$
In general (not in this case, assuming an ideal OA ), you could also have another block (transfer function) at the output.
