The light being used is here: https://www.amazon.com/Germicidal-254nm-U-shape-150mm-Purification/dp/B01CV2W12E
Lamp Current: 5.0mA Wattage: 8 watts
It will be hooked up to 2 AA batteries in series The batteries are 1.5 V and 3000 mAh
How long will the batteries last?
My first assumption is to do this: π΅π‘Žπ‘‘π‘‘π‘’π‘Ÿπ‘¦ 𝐿𝑖𝑓𝑒= πΆπ‘Žπ‘π‘Žπ‘π‘–π‘‘π‘¦/(πΆπ‘’π‘Ÿπ‘Ÿπ‘’π‘›π‘‘ π·π‘Ÿπ‘Žπ‘€)=(3000 π‘šπ΄β„Ž)/(5 π‘šπ΄)=600 β„Žπ‘Ÿπ‘ =36,000 π‘šπ‘–π‘›
But that doesn't use the wattage? Is this correct?
  • \$\begingroup\$ The amazon page says that they have a Starting Voltage of 450 V (they are discharge lamps), and there is an inverter between them and your batteries. Amazon description does not say what is the input voltage of the inverter and if it is compatible with your 2 AA batteries: check this, in a comment it is said 12V input, but I couldn0t see it. After triggering the lamp (see initial discharging voltage of 900 V), the inverter stabilizes between 4 and 9 mA feeding the lamp, and this shall be highlighted in your question and used as ref. \$\endgroup\$ – andrea Sep 24 '17 at 8:20
First of all, you're ignoring that the inverter requires 12 volts. Two AA batteries in series is only 3 volts.
Second, the 5mA is the lamp current at high voltage. At 12 volts, the current will be higher. Using the 8 watts, at 12 volts, it would be at least 0.667 amps (probably a little higher due to inefficiencies in the inverter). Let's assume 1 amp.
If you use 8 AA in series to get 12 volts, at 3000mAh, you're looking at 3 hours, probably less as the voltage output drops as the batteries discharge, its unknown exactly how low it can go before the inverter shuts down.
Your formula for estimating battery life is corrected. To apply it correctly you need to use the battery discharge current not the lamp current.
Between the batteries and the lamps of your product is a DC-DC converter that steps up the voltage from 3V to Vlamp. 8W is likely the lamp load power.
Assume the DC-DC converter is 100% efficient. The power drawn from the batteries will also be 8W.
$$ P = IV $$
$$I_{batt} = \dfrac{8}{3} = 2.67 \text{A} $$
Using a discharge current of 2.67A yeilds a battery life of a little over an hour.
Addition of lamp specifics
However the power consumed by the device may be slightly lower than 8W. Since they also reference a lamp to run at approx 5 mA @ 400V, which is 2W each. Which would mean a 50% efficient DC-DC converter (also very plausible).
    \$\begingroup\$ You probably didn't check his link. The inverter is listed as using 12 volt input. I'm doubtful it'll work on 3 volts. \$\endgroup\$ – DoxyLover Sep 24 '17 at 6:04
  • \$\begingroup\$ @DoxyLover Ohh, I see the input is listed in the title not in the specs good catch. \$\endgroup\$ – sstobbe Sep 24 '17 at 6:10
By clicking β€œPost Your Answer”, you agree to our terms of service, privacy policy and cookie policy
