I am using SSM3J334R P channel MOSFET for switching high voltage which has following specs
Drain-Source voltage (VDSS) -30 V
Gate-Source voltage  (VGSS) ±20 V
There are two ways to protect the Gate of the MOSFET from excessive voltage or exceeding the Vgs.
One is voltage divider which is cheapest method to drop the voltage, but it has one disadvantage i.e with the increase in voltage the gate voltage will increase accordingly and at some point it may be exceed the rated voltage of Vgs of MOSFET.
Other is having zener diode in parallel with resistor
In both the circuits the Diode at drain is stop reverse flow of the current as the electronic connected to the output has two power source one is this MOSFET and one is direct 12V which share common ground with this circuit, reverse current turn on the circuit as it receives 12v and 5v is generated and MCU is ON which is undesirable.
  1. Which method is more reliable to protect the gate? The nominal voltage for switching will be 12V most of the times, but it may go upto 24V sometimes as well.
  2. Is 1K pull up enough to turn off the MOSFET when Transistor is off.
  3. Is there any chance the MOSFET gets damaged from high voltage and high voltage flow through transistor base and to MCU GPIO. If yes, how to avoid that ?
  4. What should be the ideal value of Zener Diode, the Vgs(max) of MOSFET is 20V.
The second circuit may blow-off either the BJT or the zener (or both), if 12V_IN actually is larger than 15V...
You must add a resistor as shown here:
To answer your question:
  1. The most reliable way is the zener, provided that you put the resistor as indicated.
  2. 1k not only is enough, but might be unnecessarily low, if you don't want high speed switching. Much larger values (>>10k) can be used if you are going to use this circuit to power on/off some devices in your system.
  3. Voltage does not flow. There will be damage if you apply a high voltage (i.e. higher than the voltage supply of your MCU) to a GPIO pin or if you exceed any voltage rating of your MOSFET.
  4. If \$V_{GS,max}\$ is 20V, then you should make sure that this voltage is not exceeded. You can't use a 20V zener (Zeners, like all components, have some tolerances). Your 15-V zener is ok, but also a 10-V zener would be ok.
  • \$\begingroup\$ Why is resistor required, as you suggested? What will be the value? \$\endgroup\$ Sep 24, 2017 at 9:35
  • \$\begingroup\$ I can't use 10K, switching time is very less, about 10ms. \$\endgroup\$ Sep 24, 2017 at 9:36
    \$\begingroup\$ The resistor is required if you, let's say, use 24V instead of 12V. Let's assume that the current gain of Q1 is only 30 (minimum on the datasheet). The base current is 4.3 mA, therefore the collector current will be 130 mA. If the zener voltage is 15V its power dissipation will be 2W. On the BJT there will be the remaining voltage, i.e. 9V. Which corresponds to a power dissipation of 1.2W. Both components will likely burn out. The higher the gain, the higher the current, the higher the power dissipation. The resistor prevents this by limiting the current to \$(V_i-V_z)/R\$. \$\endgroup\$
    – next-hack
    Sep 24, 2017 at 13:19
    \$\begingroup\$ @LearnerLearner. Ok, let's assume that Q1, when ON, is like an ideal switch. If you have 24V and Q1 is ON, you are applying to a 15-V zener diode a voltage of 24V. This will destroy your zener diode as a huge current will flow. If you put the resistor, then, the resistor R will "eat" the 24V-15V = 9V. And the current will be limited by the resistor. If R is large enough, the current will be low enough not to destroy your zener. \$\endgroup\$
    – next-hack
    Sep 25, 2017 at 13:57
    \$\begingroup\$ @LearnerLearner You have two constraints: 1) speed. The larger the resistor, the larger the time constant \$R \cdot C_{in}\$ (\$C_{in}\$ is the MOSFET input capacitance shown in the datasheet). And the longer the turn-on time 2) Power dissipation on the BJT and Zener. Since you'll put the BJT in saturation, the larger dissipation will be on the Zener. If you put 1kOhm, there will be roughly 9mA @Vin=24V. The power dissipated on the zener will be 135mW, i.e low enogh for many zener diodes. \$\endgroup\$
    – next-hack
    Sep 25, 2017 at 19:21
