How to constrain the paths without registers?
Yes, there is a way. Timing paths don't have to be from register to register. A port also can be a startpoint or endpoint. If your block is completely combinational, all paths will be from input ports to output ports.
The most important thing here is to define a virtual clock and input/output delays in an XDC file. Then you must add the file to the Vivado project.
create_clock -name VCLK -period 10.0 -waveform {0 5.0}
set_input_delay 1.0 -clock [get_clocks VCLK] [get_ports IN1]
set_output_delay 2.0 -clock [get_clocks VCLK] [get_ports OUT1]
The example above tells that IN1
signal arrives to the block 1ns after VCLK
rises. In addition, OUT1
has to be set 2ns before VCLK
rises. Since our clock period is 10ns, the path from IN1
to OUT1
has 7ns (10-1-2) to finish the operation.
How to see the critical path in Vivado?
Once the implementation is completed, click "Reports" at the bottom of Vivado GUI. Then click "Timing Summary Report" under "Route Design". As an alternative, you may also search blabla_timing_summary_routed.rpt file in the project directory.
This report shows the critical paths for all clock domains. Since you have only one clock domain, you should see something like below.
From Clock: VCLK
To Clock: VCLK
Then find the section "Max Delay Paths". You will see the critical path below it.
