I came across a question which says the following,i don't understand the question and how to come up with a solution
In fig,the data word to be stored is S=1001
a)If LOAD is LOW,what does Q equal after the positive clock edge?
a)If LOAD is HIGH,what does Q equal after the positive clock edge?
It'd be really helpful if someone explains the solution,I got the basic knowledge about flip-flops
The LOAD signal here functions as a Synchronous Active-Low Reset. As long as LOAD is 0, the flops will get loaded with 0 on clock's positive edges. When LOAD is high, whatever value that's present on {S3 S2 S1 S0} will get loaded into the flops on positive clock edges.
| improve this answer | |
As the flip-flops are gated with AND-gates, when LOAD is low, 0 will be fed into the FF. When LOAD is high, the word 1001 is fed into the FF.
