Given z transformed function is E(z)=1/(z+4)
I know there are several ways to get the inverse z transform of this function.
  1. use partial fraction
E(z)=1/(z+4)
E(z)/z=1/z(z+4) apply partial fraction here,
E(z)/z=(1/4)*((1/z)-(1/(z+4)) so E(z) is,
E(z)=(1/4)*(1-(z/(z+4)) as you know, it is easy to use inverse z transform here.
e(k)=(1/4)*(delta(k)-(-4)^k)
  1. inversion formula method
E(z) has simple pole at z=-4, the residue is evaluated as
{(residue)|z=-4} = {(z+4)*E(z)*z^(k-1)|z=-4
             = {1*z^(k-1)|z=-4}
             = (-4)^(k-1)
             = -(1/4)*(-4)^k
The problem is that inverse z transform of the same function E(z)
has 2 different answers. As you see, there is no delta function when I used
inversion formula method.
At first, I thought it was because a simple pole,z=-4, is outside of the unit
circle, but same things happen when I used a simple which is inside of the unit circle.
Why does this difference happen?
What is the real answer?
  • \$\begingroup\$ This isn't explicitly an EE question - there are better sites for raising questions like this. \$\endgroup\$ – Andy aka Sep 26 '17 at 10:27
The equations do produce the same results. \$\small e(k)\$ is assumed unilateral, so the equations in method 2 should be qualified by \$\small k>0\$, thus:
$$\small e(k)=\begin{cases} (-4)^{k-1}= -(1/4)(-4)^{k}, \:\:\:k>0 & \\\\ 0, \:\:\text{otherwise}\end{cases}$$
Also, remember that:
$$\small \delta (k)=\begin{cases} 1, \:\:\:k=0 & \\\\ 0, \:\:\text{otherwise}\end{cases}$$
