I've recently tried to make conversion from EGA (probably, couldn't get scope to verify) to VGA to replace an old factory CRT monitor to LCD.
Screen displays fine but it appears to shake vertically in a terrible manner that make it hell to read information from it. Video presentig the issue is linked below. What may be possible cause of this issue?
vimeo .com/235485641
EDIT: Some informations that might appear to be useful (most have been asked in comments section):
i'm using GBS-8200 CGA/EGA to VGA converter (manual for this one specifically is here: arcadeworlduk.com/content/CGA-VGA-Manual.pdf),
i'm trying to pass signal directly from machines graphic card monitor socket
I've soldered 6 cables to the bottom of monitor graphic card and connected them to the converter's P11 as follows:
(GROUND->black, GROUND->none, VS->white, HS->none, S->yellow, B->blue, G->green, R->red)
- frequencies on yellow/white pins are: yellow-15-17Hz, white-18-21Hz
