I have established a circuit which has a -7V,+7V 16kHz square wave and my aim is obtaining 0V,+1V 16kHz square wave output signal. To do this, i have used a TI SN75189ADR and DMP4051LK3-13 pmos as i mentioned below;
Because of the inverting function of the SN75189ADR, i used pmos for switching and with a voltage divider configuration, i have tried to obtained 0V,+1V square wave. I have almost reach my goal however there is a long falling time as 4.4 us at the output. I have shown below "±7V_SQUARE_WAVE_INPUT" as yellow signal and "MOSOUT" signal as blue;
I have realized that the low falling time is also at the "RCOUT1". I think the output of the SN75189ADR is dependent to its load. I have changed the pmos but the lack was still there. Do you have a suggestion about how i can decrease the falling time on the PCB (I can use some capacitors or resistors on board but i can't change the configuration because PCB was produced.)? Thank you.
  • \$\begingroup\$ Add a resistor gate to rail ~500R will help. \$\endgroup\$
    – Trevor_G
    Sep 26 '17 at 17:36
    \$\begingroup\$ What is the intended load not shown? Because this design is sub-optimal for a clean square wave , even with no load \$\endgroup\$ Sep 26 '17 at 17:46
The problem is most likely the SN75189. It has an BJT to pull the output low, but only an 1.66k resistor pulling up. Which means it will take a lot of time to discharge the gate capacitance of the FET. I would use another chip that can do the 7V->1V directly. Or if you cannot find one, there are easier to do transistor based circuits that one can use.
Low RdsOn FETs (85 mΩ) have high input capacitance (674 pF typ) and TTL with ~ 5K pullup on open collector is a poor drive source here.
Use my Rule of Thumb on drive out/in impedance ratio. I usually limit this impedance to 200:1 for a more ideal response. Not to mention impedance is asymmetric on both inputs and outputs.
You would get a better response with a CMOS buffer.
Your impedance ratio source/out for logic "1" is 5kΩ/85 mΩ or almost 60k:1 , so it is slow !
Your RC time constant 674pF(@ 0Vgs) * 5k = 3.3us which is close to your fall time and you also have high latency.
