I'm running my first CAN test program using STM32CubeMX, STM32F103C8T6 and Eclipse.
I used default CAN settings in STM32CubeMX (also tried loopback but the results are equal).
What I see (see pic below) is two things I do not understand;
  • In the picture below, you can see I exceeded the line with hcan.pTxMsg->StdId = 0x321 (left red oval), but the current value shows 536891392 (right red oval).
  • When I execute the next line (green): hcan.pTxMsg->ExtId = 0x01, I end up in a hard fault interrupt:
    • @brief This function handles Hard fault interrupt. / void HardFault_Handler(void) { / USER CODE BEGIN HardFault_IRQn 0 */
      /* USER CODE END HardFault_IRQn 0 / while (1) { } / USER CODE BEGIN HardFault_IRQn 1 */
      /* USER CODE END HardFault_IRQn 1 */ }
Why is the value not updated and why do I get a hardware fault (the pointer hcan.pTxMsg is not NULL since it even displays the field StdId (it even can display ExtId which has value 134222077 (not shown in pic below)?
screenshot
    \$\begingroup\$ Just a wild guess, but did you set hcan to a valid instance (CAN1 or whatever it is called in ST)? Similar the the message pointers. If they are pointing at garbage, something like this might happen. \$\endgroup\$
    – Lundin
    Sep 27, 2017 at 11:14
  • \$\begingroup\$ @Lundin ... you pointed me in the right direction. For my future reference and others, I added it as answer. Thanks for your comment. \$\endgroup\$ Sep 28, 2017 at 23:13
By default STM32CubeMx create the initialization code for 'can' (if selected). This code can be found in MX_CAN_Init and is called by main.
However, it does not assign/initialize the pRxMsg and pTxMsg.
The pTxMsg should be defined as:
CanTxMsgTypeDef txMessage;
hcan.pTxMsg = &txMessage;
and the pRxMsg as:
CanRxMsgTypeDef rxMessage;
hcan.pRxMsg = &rxMessage;
