So I’m trying to run a 3.7V motor off of a mosfet, and it works perfectly fine when I provide a 3.7V PWM signal to the gate of a FQP30N06L.
However, when I swap out that mosfet for the RFP30N06LE, it does not work. It did work when I provided it 9V however. I don’t understand why this is the case, I have compared the two data sheets and they are nearly identical, yet the LE does not seem to be even reaching its threshold voltage at 3.7V.
I have tried connecting the gate directly to a 3.7V rail instead of PWM pin but to no effect. I have 220 ohm resistors on the gate and I have tried with and without a 10k pulldown resistor, still nothing. Any ideas?
  • \$\begingroup\$ Can you add a schematic to show exactly how you're connecting this stuff? \$\endgroup\$
    – BeB00
    Sep 27 '17 at 2:03
    \$\begingroup\$ You sure you have the correct MOSFET? The RFP30N06 has a Vth of 2V, did you maybe receive a high Vth part instead? \$\endgroup\$
    – John D
    Sep 27 '17 at 2:33
  • \$\begingroup\$ THese specs are far from identical at 3.7V \$\endgroup\$ Sep 27 '17 at 3:07
  • \$\begingroup\$ Did you just use the flange as the Drain? That would explain it. \$\endgroup\$ Sep 27 '17 at 3:15
  • \$\begingroup\$ @TonyStewart.EEsince'75 But even so its far above the threshold voltage, so shouldn’t it still be allowing current through? \$\endgroup\$ Sep 27 '17 at 3:15
i agree with @Leroy105 on the fact that the fets may be different, however i wonder if you are connecting the source to the load rather than to 0v, that would rise the source voltage hence the gate source voltage would be lower which in turn may reduce the output current, and according to the datasheets of both fets that should happen in a more apparent in the RFP30N06LE since it has a slightly higher vTh which means that the voltage at the load should be lower for the fet to activate and hence lower would be the current at the load
  • \$\begingroup\$ I have the drain connected to the load and source directly to ground \$\endgroup\$ Sep 27 '17 at 18:11
  • \$\begingroup\$ in that case id recommend you to do a sweep in the gate to determine the threshold voltage, maybe you got a bad fet as leroy105 said \$\endgroup\$
    – diegogmx
    Sep 27 '17 at 18:28
Unless you bought the parts from reputable sources such as Digikey, Mouser etc., you can be 100% certain that your parts are Chinese fakes which do NOT satisfy any of the specs in the corresponding datasheet.
The max Vgs(th) of a genuine RFP30N06LE is 2 V, so it would definitely turn on at 3.7 V. Since it did not, your part is certainly a Chinese fake. Buy a genuine part and you'll be happy.
China's manufacturing industry is so huge that they have extra capacity to make fakes for anything they produce.
  • \$\begingroup\$ Well its a possibility. 2 comments on that. 1st: even reputable sources may deliver faked parts... happens. and you need a qualified lab or the manufacturer to validate on that. 2nd: The part might still simply be damaged in some way. If you have not multiple parts from the same source/batch, you can't tell \$\endgroup\$
    – schnedan
    Sep 21 '20 at 10:12
  • \$\begingroup\$ Hobbyists in the US tend to source their parts from Ebay or Aliexpress because they're normally much cheaper. (including the S/H charge). Unfortunately, most parts from Ebay and expecially Aliexpress are Chinese fakes.. They may just slap the part number of a logic level MOSFET on a (also fake) non logic-level MOSFET and sell it just like that. A (brand-new) logic level MOSFET (RFP30N06LE ) that only turns on at 9V is a clear indication of a fake MOSFET :-) \$\endgroup\$ Sep 24 '20 at 20:13
I've seen this before with a circuit using a name brand FET and a cheap cheap Asian FET. This is in a consumer product. One cent FET vs 12 cent FET.
The RdsOn value, even if stated as the same in datasheets, may be different...
I didn't believe it at first, I deep dived this circuit and checked everything and that was the final conclusion. Datasheet specs were claiming same RdsOn but clearly not. Don't always believe what you read...
We are still working on sourcing a suitable FET for a penny. Haha
    \$\begingroup\$ What is the value of unreliable Sources to Drain your reliability. This is the Gate to failure. \$\endgroup\$ Sep 27 '17 at 13:26
