I am trying to implement a non-inverting operational amplifier circuit; essentially, to double the potential difference of a shunt using the differential amplifying effects of the op-amp, so that I may be able to measure current through it without blowing an ammeter. The schematic I am referencing is:
The following is my attempt at its implementation on the breadboard:
As can be seen on the multimeter, the circuit does not function correctly. Can someone help?
