I've been refreshing my memory on clock recovery, and I've hit some issues trying to understand how the recovered clock can be practically used to latch data bits from the input data stream.
For simplicity, let's assume a NRZ line code, such as 8b10b. Because of NRZ encoding, the data stream will transition if a logical 0 follows a logical 1 or vice versa. Any transition on a wire carrying NRZ data will be due to the transmitter clock latching a new bit to be sent.
Assume an analog PLL which generates a square wave on the VCO, an edge detector on the data stream input which creates positive pulses on each transition of the data stream (see page 34 of 2), and a positive-edge-triggered Phase-Frequency detector (see page 35 of 2) which generates the phase difference.
In a traditional clock recovery setup using a PLL/edge detector, the recovered clock's positive edge will eventually align to the transitions in the received bit stream, and thus be aligned to the transmitter's clock.
The problem I see with aligning to the transmitter's clock is that when using the recovered clock to latch the input data into a flip-flop, immediately after latching (or possibly even before due to jitter! A PLL can't lock on to the exact frequency), the data stream as seen by the flip-flop's input will transition. Although small, this is a hold (setup) time violation for the flip-flop. Additionally, I recall that sampling as far away from transitions as possible is ideal to accommodate for jitter.
However, none of the sources I've been reading discuss any solution to my perceived issue of "using the recovered clock as-is to shift in input data". The closest I've seen is a diagram implying that the recovered clock should clock a flip-flop fed with the input data stream.
The naive solution I would use would be to "invert the recovered clock before feeding it to the flip flop which latches the input data". Assuming the problem I perceive exists, what solutions are used to work around the issue?
  • \$\begingroup\$ I don't completly understand what problem you are trying to refer to. What I can say is that often you might not go directly to a digital flipflop but through a filter instead. In order to ensure the PLL is locked properly, usually packets have preables attached to them that contain a good number of transitions such that the clock-recovery can get as good an idea of the clock as possible before actual data arives. \$\endgroup\$
    – Joren Vaes
    Commented Sep 28, 2017 at 14:23
  • \$\begingroup\$ @JorenVaes The problem I'm trying to refer to is that I don't see how you can use the recovered clock to shift in received data when the recovered clock will have its positive transition (assuming positive edge flip-flops) at the end of a bit period, not at the center. Sampling should always be done at the center of a bit period. \$\endgroup\$
    – cr1901
    Commented Sep 28, 2017 at 14:29
    \$\begingroup\$ The recovered clock has two edges. If you synchronise the rising_edge to the data transitions, the falling_edge will be near the middle of the eye, and vice versa. This may be too obvious for the sources to mention... \$\endgroup\$
    – user16324
    Commented Sep 28, 2017 at 14:32
  • \$\begingroup\$ @cr1901 Why would the phase edge be fixed in that location? The phase of the clock has to be made such that you have your transitions in the right place. \$\endgroup\$
    – Joren Vaes
    Commented Sep 28, 2017 at 14:37
  • \$\begingroup\$ @JorenVaes The positive edge of the received clock is locked to the transitions of the input data. The input data only transitions in response to the positive edge of the transmitter clock (0->1 or 1->0). Thus, if your receiver clock is locked, it is locked such that the positive edge transitions are when the data is transitioning, i.e. the end of a bit period. \$\endgroup\$
    – cr1901
    Commented Sep 28, 2017 at 14:42
4 Answers 4
I think this may be glossed over in some of the literature because obviously you want to sample the data in the middle of the data bit (sampling accurately in the middle of the data bit is a large part of ensuring high jitter tolerance), so obviously you're going to phase shift or delay the clock or the data somewhere along the line by 90 or 180 degrees, so it's not necessarily mentioned. There are a bunch of ways of doing that. Invert the clock is one. Fixed phase shift with an analog technique such as a filter, hybrid coupler, or delay line also works. Quadrature or differential outputs on the VCO is another option. If you're not using a PLL but are instead using phase interpolators or tapped delay lines, the usual solution is to use two phase interpolators or delay line taps that are held 90 degrees apart by the control logic, one to look at the edges and the other to look at the data.
Let's take a look at a couple of commercial parts and see how they do it. First, a 30 Gbps GTY transciever out of a Xilinx Ultrascale FPGA (from UG578 page 192):
Virtex Ultrascale GTY RX CDR block diagram
There you have it, two phase interpolators, one looking at edges and one looking at data. The control logic detects transitions and checks to see if it's sampling the edges too early or too late and adjusts the phase interpolator taps accordingly, keeping a 90 degree offset between the two so the data is always sampled exactly half way between the transitions that it has locked on to. It can track a frequency difference between the internally generated reference frequency (half line rate) and the actual receive line rate of up to +/- 200 ppm (above 8 Gbps).
Here's what those sample points look like (UG578, page 193):
CDR Sampler Positions
How about a part that actually uses a PLL with a VCO to recover the data? Well, this technique seems to have fallen out of favor, at least for modern high speed serial stuff. Not entirely sure why, but I presume it's beause building VCOs is a pain and if you use phase interpolators then you can share a VCO across several transmitters and receivers instead of requiring one per receiver. Anyway, here is the block diagram for a Lucent LG1600FXH, an older (1999!) part for retiming SONET up to 5.5 Gbps (LG1600FXH datasheet, page 2):
LG1600FXH block diagram
Hey, look at that, their VCO has quadrature outputs! Actually, that's a bit of a red herring. In this case they are using the in-phase output to clock the capture flip-flop, but they also aren't locking the VCO onto the data directly, they're locking onto the output of an edge detector (LG1600FXH datasheet, page 3):
LG1600FXH Frequency and Phase Detector
The edge detector uses a tuned delay line and an XOR gate to produce pulses that the PLL locks on to. These pulses start on transitions, but the pulses are tuned by the delay line to be exactly half of the data bit width (LG1600FXH datasheet, page 3):
LG1600FXH Timing diagram
It looks like with the way the phase detection logic works out, the PLL actually locks inverted with respect to the edge pulses. Because of the tuned delay from the edge detector, the PLL locks with the in-phase output rising edge smack in the middle of the data bit.
I will also note that the LG1600FXH is actually a hybrid integrated circuit with several discrete components on a ceramic substrate. That's probably the only real way to get away with building a stub delay line based edge detector like that. The LG1600FXH datasheet also has a rather extensive theory of operation section; I recommend taking a look at it.
A major advantage of the phase interpolator based CDR circuits is that they are usually capable of operating over a very wide range of line rates, and they are relatively easy to reconfigure for a different line rate. For example, the GTY transceivers in the Xilinx Ultrasacale series FPGAs are capable of covering essentially the entire range of 500 Mbps to 30 Gbps, switching between two different PLLs and several divider settings as necessary. PCI express links always come up initially in gen 1 mode (2.5 Gbps per lane), and then negotiate up to higher speeds (gen 2 at 5 Gbps or gen 3 at 8 Gbps per lane). The links can also be renegotiated on-the-fly for power/performance trade-offs (for example, a laptop discrete GPU falling down to gen 1 when not being actively used, then switching to gen 2 or gen 3 when watching a video or playing a game).
For the LG1600FXH and other CDRs based on analog delay methods, the problem is that the edge detector generates pulses of a fixed duration. The result of this is that the range is much more limited, only a handful percent around the design line rate. As the line rate diverges from the design line rate, the jitter performance will degrade as the data sampling point moves away from the center. Even further out, and the edge detector and phase detectors won't work properly, causing the PLL to not lock reliably. And the delay line cannot be re-tuned as it's physically cut to length during manufacture.
  • \$\begingroup\$ Excellent answer that restates my issue and discusses various solutions on how to actually use the recovered clock. +1 and accepting. \$\endgroup\$
    – cr1901
    Commented Jun 7, 2018 at 11:21
  • \$\begingroup\$ (I came back to this answer after a while because I needed a refresher): All the real world examples you show use a clock that's 90 degrees out of phase to recover the data. You mention inverting the clock (180 degrees) as a solution. Are there real-world clock recovery designs you can point to that use 180 degrees? I realized that inverting the clock doesn't actually solve the "setup/hold time" problem, unless the recovered clock is double the freq of the data stream transitions. 90 degrees out-of-phase seems to avoid doubling the freq? \$\endgroup\$
    – cr1901
    Commented Apr 17, 2021 at 15:50
Use a Ring Oscillator with differential inputs and output. A 2-stage Ring Oscillator provides all 4 quadrature choices of clocking, and the differential nature provides substantial rejection of GND and VDD noise. As the highest operating frequencies, the generation of rail-rail clocks is very difficult, and CML current-mode-design should be considered.
  • \$\begingroup\$ What do you mean by "differential nature"? Additionally, will a ring oscillator's jitter be low enough to use the 180-degree out-of-phase output to clock in data from the output of the clock recovery circuit? \$\endgroup\$
    – cr1901
    Commented Sep 28, 2017 at 20:05
I did a design where we inverted the clock to solve this. But then you have negedge flops which cause other problems. You can also use a b latch to get the same effect. Usually we just let the physical design team treat it as a timing constraint and make sure the data doesn't violate the setup/hold window.
  • new answer
    • 8b10 replaces 8 data bits with 10 bits , ensures an equal number of 0's and 1's , offers unique codes for sync, may be scrambled.
    • Recovery replaces the 10 bits with the original 8 data bits
    • Recovery can be digitally phase locked using a 5x clock such that the data is always sampled at the best mid-data transition position.
    • Numerous methods of pre-compensating phase shift during the encoder process to null some of the effects of intersymbol interference and group delay, as well as integrating the phase difference between clock and data edges.
  • old answer
The clock and data recovery or CDR needs to achieve frequency lock before it can achieve phase lock and retime the input data.
Frequency acquisition is accomplished with two key sections. The first section is a secondary frequency lock loop (FLL) that drives the VCO towards the desired frequency. A lock detector then enables a PLL. Data activity must be present with 50% transition density for the CDR to function.
The Phase error is used to correct the clock phase by an averaged amount of phase error to reduce the jitter from tracking data symbol jitter. This is optimized based on the system parameters.
Tx Pre-compensation uses both tri-level and phase shift to minimize intersymbol interference (ISI) from group delay distortion and frequency dependent attenuation. Post-compensation Rx filters are also used. This results in improved Eye Patterns.
The exact means of phase lock may be patented and proprietary. Some may be digital and use both edges and levels to integrate the phase error over the entire symbol and others may only be dependent on data edge transitions.
In general FLL and PLL designs depend on the frequency stability of the source and phase stability in the channel with resulting SNR, jitter margin and phase error margin for low error rates (BER).
For example I once designed an NRZ CDR with video quality SNR that only relied on a short sync pattern and then 1 bit transition per 1000 bits (not 50%) because the clock stability and signal SNR were good. Thus phase correction could be done easily.
  • \$\begingroup\$ I'm having trouble visualizing the connections between the "two key sections (FLL and PLL)". Do you have a diagram? \$\endgroup\$
    – cr1901
  • \$\begingroup\$ "The Phase error is used to correct the clock phase by an averaged amount of phase error to reduce the jitter from tracking data symbol jitter" Is the "averaging" due to the loop filter of the PLL in the FLL/PLL combo, or is the averaging accomplished through other means? \$\endgroup\$
    – cr1901
    Commented Sep 28, 2017 at 20:09
  • \$\begingroup\$ FLL and PLL use different filters and mixers \$\endgroup\$
    – D.A.S.
    Commented Sep 28, 2017 at 20:31
  • \$\begingroup\$ Although your info is very useful (and I will likely use it to ask follow up q's), my question was about how to use the output of a clock recovery circuit to latch the input data stream (based on the assumptions of the PLL circuit in the question). I'm wonder if the naive way of "just use the negative edge" is the best way or there are other techniques to phase shift the recovered clock. \$\endgroup\$
    – cr1901
    Commented Sep 29, 2017 at 0:20
