I recently bought this fan, I am trying to power it for an external project that doesn't revolve around laptops; however, I don't know how to get power to the fan without cutting off the molex connector and stripping the wires.
I know this is a female molex connector, but I can't find any male heads that even remotely fit this type of product, so I ask you guys if you know of the specific molex connector that I can use to plug into this connector and get power to it.
Thanks
    \$\begingroup\$ Can you post a close-up of the connector? How do you know it's Molex? Does it have any markings? How far apart are the pins/sockets? Also, if you say what make of laptop it's designed for someone might know from that. Laptops rarely use the standard connectors that desktops use. \$\endgroup\$
    – Jack B
    Commented Sep 28, 2017 at 15:53
    \$\begingroup\$ @winny that's not even what op is asking 😒. It's a part identification for the connector. \$\endgroup\$
    – Passerby
    Commented Jan 23, 2018 at 5:32
Check the pitch and find something that matches on digikey (you might end up checking 20+ mechanical drawings, but thats the nature of these problems. Another option is to unsolder a connector from a laptop motherboard, just find a connector with the same pitch.
Third option, if the connectors aren't to small the 0.1" jumpers might fit into the end of that connector and into a breadboard.
But it would be far easier to learn how to use a soldering iron, find a 4 wire connector that you can use, and splice the wires. Soldering irons can be found for as low as 10$.
You could use the connectors that you use on breadboards, plug one end into the connectors on the fan and solder the other end to your power source, I often use this method on connectors on items that I want to use as it was originally intended as well as for my own uses.
