4 years ago I purchased an automatic chicken pop door for my coop. It is 12 volts and the door opens at dawn and shuts at dusk by means of a photosensor. It is a home built device that works quite well. It stopped working recently. Of course, I took it apart to diagnose the problem and made a sketch where all the wires went (they are all either red or white) and promptly lost the sketch. I need help in correctly wiring the linear actuator to the relay. Can someone tell me how to wire this? Sorry for the primitive sketch. The linear actuator is from a hospital bed and stops when it is fully extended or fully retracted. When the polarity is reversed the actuator travels in the opposite direction. The microswitch is at the bottom of the door to stop travel when an obstruction is hit and signals that the next direction of travel is in the opposite direction. The relay is an Omron LY2N-J DPDT on a PTF08A base. The wiring shown I KNOW to be correct. I just do not know where to attach the switch (possibly 1 and 4) or the actuator.
It is important to me - I know I look like a rube - I'm not electronically oriented but can handle the wiring.
