I was soldering some components on a PCB and suddenly i realized that i soldered a wrong resistor (i should solder a 10k ohm and I did solder a 1k ohm). I tried to remove it, with iron solder (it wasn't my first time), but for some reason a resistor's leg just got stucked and in the end broke it (violence and electronics are mutual exclusive, I know), letting a piece of the leg soldered on the board.
the question is: i want to reuse the PCB, but the leg is stucked in the hole. I tried to pull it, to apply more heat, solder sucker, voodoo, etc but it didn't work. Any other Idea to
a-) remove this half-leg from the hole?
b-) maybe remake the hole?
Don't bother trying a solder sucker. Those suckers are next to useless for removing the thin film of solder between a component leg and the plating. You'd have to remove almost all of the solder in one go. If you don't then 1) the leg is still stuck in there, and 2) there's no enough solder around to conduct heat from the iron. Desoldering braid is useless for the same reason.
Your problem is that you're not getting enough heat into the solder to melt it. This can often happen if the hole has a lot of copper around it. E.G. if it's solidly attached to the ground plane (and especially if it's connected on several layers).
How to get more heat into the hole:
1) Make sure the iron tip is clean and shiny. A dirty iron tip won't conduct heat properly. Clean it with a tub of brass wool, then dip it in tip tinner. When you touch the solder onto the iron, it should melt instantly.
Brass soldering iron cleaner Tip tinner
2) Make sure the iron is touching both the resistor leg and the copper of the PCB. Again.
3) Add more solder! You need to conduct heat efficiently into the hole. To do this, you need as much cross sectional surface area as possible to conduct heat from the iron onto the resistor leg and down into the hole. Add as much solder as you want. Your goal is to get the resistor leg out. Once you've done that, you can use a solder sucker to clean out the hole (possibly, see below).
4) Grip the resistor leg. If any of the resistor leg is sticking out, you can grip it with a pair of sharp side-cutters. The reason to use these is that a) the blades will give you a good grip on the leg. b) Their sharpness means a small surface area to conduct precious heat away from the leg. Pull gently on the leg while heating with the iron. Be careful not to cut the leg by accident, it'll only make your job harder. I recommend clamping the board upright in a small vice while you're doing this.
Side cutters
5) Use another source of heat. Pre-heat the PCB with a hot air gun. When it's fairly hot (but not crazy hot) try again with the iron and side cutters. The extra bit of heat might just be enough.
Heating a PCB
Failing that, use a mini gas gun, or another iron to apply extra heat at the same time. You might need a third hand for this.
Vulkan P100
Once you have removed the resistor leg, you now need to remove the remaining solder from the hole.
1) Put the PCB upright in a vice, so you have access to both sides. Adding more solder to create good heat conduction, heat the hole from one side. Watch the other side to see when the solder there melts. When it does, press the solder sucker right up to the hole like it's giving mouth-to-mouth. Make sure the iron is still in contact with the hole, but not blocking it, as this will prevent the air flow that removes the solder. Press the sucker's button. See your perfectly clean hole.
However, this method might not work. If you were having trouble melting the solder enough to remove the leg, then you might not be able to heat it enough to suck the solder out. Try method 2.
2) Find a 0.6mm PCB drill. Twist it into the hole with your fingers. Solder is so soft that you can easily drill it out this way. Once you're through, carefully use the drill like a little file to file away the remaining solder. As ejoso mentioned in the comment below, you should remove the just enough solder as possible to get the new resistor's leg through.
PCB Drill
| improve this answer | |
    \$\begingroup\$ While I've had success with solder suckers personally, this is a great response overall - I want to underscore the CAREFUL part of drilling it out. I've had success doing this and also destroyed unseen traces within the via. Just be sure that you drill out the least amount of material possible to get your lead through - and avoid cutting into the board itself. \$\endgroup\$ – ejoso Jun 4 '12 at 2:37
    \$\begingroup\$ +1 When desoldering, more solder is the answer. When soldering, more flux is the answer. \$\endgroup\$ – markrages Jun 4 '12 at 15:20
  • \$\begingroup\$ @markrages - Yes, that's correct. \$\endgroup\$ – Rocketmagnet Jun 4 '12 at 18:53
Have you tried a solder sucker? Apply some more solder to the hole, get it hot and suck it out with something like this. (no endorsement is implied - it's just the first one I found an image of).
If that doesn't work, you could try adding solder, then heat up the hole and using the leg of another resistor or a small pick to push through the hole. The idea is to heat up the joint, and push the new lead through while it's still fluid.
  • \$\begingroup\$ hi sorry, I thought that "trying to remove it with iron solder" would imply using a "solder sucker". I did add it to my question, but thanks anyway. \$\endgroup\$ – VP. Jun 3 '12 at 21:14
  • \$\begingroup\$ but your second idea sounds interesting. I will try it. \$\endgroup\$ – VP. Jun 3 '12 at 21:14
Carefully drill it out. You will destroy the through-hole plating so you will have to solder the lead of the replacement resistor at the top and bottom pads.
In future, use desolder braid when removing components, or a suitable desoldering system.
Use solder wicker. After this use a lot of flux and another pass with fresh solder wicker.
