I am making a schematic of a PCB in Orcad Capture. I have to place a jumper. Does anyone know the part number for a jumper or the library where it can be found?
  • \$\begingroup\$ What do you mean by jumper? A 2 pin header that can be shorted on the board, or a symbol that allows you to assign multiple names to the same schematic net? \$\endgroup\$
    – Justin
    Jun 4, 2012 at 15:00
  • \$\begingroup\$ Why not create your own part? It would only take a minute or so with the PCB software I use. \$\endgroup\$ Jun 4, 2012 at 15:11
In Orcad Capture the jumper symbols are contained in the "CONNECTOR" library.
If this library has not yet been added to your project, this is how you find it:
  1. Open the "Place Part" sidebar.
  2. Open the "Search for Part" section at the bottom.
  3. Search for "JUMPER*".
  4. Double click any of the elements found to add the "CONNECTOR" library to your project.
