I have a real time clock module in my layout (same parts as this module from Sparkfun: https://www.sparkfun.com/products/12708 ), when I have my system set up WITHOUT the backup battery, I am able to see the time and date on the serial monitor, but when I plug in the backup battery, the serial monitor immediately stops outputting this information.
I checked the SCL output of the DS1307 RTC module on a oscilloscope before the battery is added and I can see the master clock signal, but when the battery is inserted, this reading flatlines...
Here is the closeup board schematic (the RTC module is indicated by U9 (backwards text)): enter image description here
And lastly the wiring schematic: I can't add since my rep is too low, so just comment if you need it
If there is anything else I can provide to help debug, please let me know!
    \$\begingroup\$ Is your battery shorting any via? Or causing the battery holder to do so? \$\endgroup\$ – Wesley Lee Oct 3 '17 at 23:16
    \$\begingroup\$ Put a link to the schematic in the comments and one of us can add it to your question. A picture of your actual board would be good too, as Wesley said, your battery may be shorting a via, pictures of the soldermask would be very helpful. \$\endgroup\$ – uint128_t Oct 3 '17 at 23:41
  • \$\begingroup\$ @WesleyLee was absolutely correct. The via furthest to the left was shorting when the battery was inserted. You can write this as an answer and I'll mark it as correct \$\endgroup\$ – Jordan Lewallen Oct 3 '17 at 23:42
When placing the battery, its body can be shorted to one or more vias. Or its placement can cause the holder to deform and short vias.
A quick fix could be placing some Kapton tape or other insulating material on the PCB.
A way to help prevent this from happening during design is creating restricted areas for vias/pads/traces on the package, so DRCs should warn you:
p.s.: apparently DRCs will ignore manually placed vias conflicting with vRestrict, so for manually placed vias you need either tRestrict or bRestrict. It seems that vRestrict was intended for the autorouter.
