Open loop gain comes from the internal circuit of op-amp which is very high, but in closed loop configuration the gain is limited by the feedback resistance. So my question is:
- What happens to open loop gain which should be there, because we haven't disturbed the internal circuit of op-amp after closing the loop around?
- If open loop gain still exists, then how can the two different voltages exist on same output node (one due to open loop and other due to closed loop)?
