-2
i am a mechanical engineer i have a question on a transistor. what happens if i apply a +ve terminal to base and negative terminal to emitter in a NPN transistor with no wires connected to the collector
    \$\begingroup\$ Some current will flow from base to emitter. \$\endgroup\$ – mkeith Oct 5 '17 at 2:33
    \$\begingroup\$ The base/emitter junction will act like a diode, and conduct current. \$\endgroup\$ – Peter Bennett Oct 5 '17 at 2:53
  • \$\begingroup\$ If you do not limit the current, you will let all the magic smoke out. Just like ballbearings go up in smoke. \$\endgroup\$ – analogsystemsrf Oct 5 '17 at 3:13
  • \$\begingroup\$ @PeterBennett move your comment to a answer. \$\endgroup\$ – MatsK Oct 5 '17 at 4:39
  • \$\begingroup\$ if you invite a guy to answer, and nobody posts something better, accept it. \$\endgroup\$ – dandavis Oct 5 '17 at 6:45
