I'm new to this arduino world. I'm trying to communicate with my arduino nano and SIM800L. I read few things in the internet and found a basic code. I tried copying it and tried to work it out, but I'm not getting the response as expected. I'm posting the code which I tried:
#include <SoftwareSerial.h>
SoftwareSerial mySerial(11, 10); // RX, TX
void setup()
  // Open serial communication
  Serial.begin(9600);
  // set the data rate for the SoftwareSerial port
  mySerial.begin(9600);
  delay(1000);
  Serial.println("Testing SIM800L module");
  Serial.println();
  Serial.print("Sizeof(mySerial) = "); Serial.println(sizeof(mySerial));
  Serial.println();
void loop() // run over and over
  if( mySerial.available() )
    char c = mySerial.read();
    Serial.print(c);
  if(Serial.available())
    String Arsp = Serial.readString();
    Serial.println("Serial available");
    Serial.println(Arsp);
    mySerial.println(Arsp);
    Serial.println("Serial available end");
I tried to send AT command and the output I received was:
Sizeof(mySerial) = 31
Serial available
AT
I don't get OK, which I should receive, it's returning empty.
I don't understand what's going wrong. Can someone help me with it?
  • \$\begingroup\$ Have you checked the baudrate of SIM800? \$\endgroup\$ – Abel Tom Oct 5 '17 at 9:14
  • \$\begingroup\$ Yea, it's 9600. \$\endgroup\$ – Electronic Brat Oct 5 '17 at 9:20
  • \$\begingroup\$ @AbelTom: I've updated my question. Take a look. \$\endgroup\$ – Electronic Brat Oct 5 '17 at 9:22
  • \$\begingroup\$ How are you resetting the SIM800L? A link to the SIM800L module that you're using may help, since there are many available. \$\endgroup\$ – Steve G Oct 5 '17 at 9:31
    \$\begingroup\$ @AbelTom As far as I remember sim800 doesn't work @ 5 V. It is some small range around 4V \$\endgroup\$ – MaNyYaCk Oct 5 '17 at 13:24
Just include '\r\n' after command AT.
For example (test the code below):
sim800.print("AT\r\n");
at_cmd_return = sim800.readString();
Serial.println(at_cmd_return);
delay(4000);
Att,
Use #include <string.h> at the start since you can't use any string without the initialisation. Otherwise, your code should be working.
  • \$\begingroup\$ i mean use #include string.h. \$\endgroup\$ – alex mwita Nov 18 '17 at 15:09
  • \$\begingroup\$ Its been a while since I did any work with the arduino libraries, but my recollection is that string functions are included automatically without needing a header. \$\endgroup\$ – Jules Apr 22 '18 at 19:37
