I'm trying to get the transfer function of a simple passive pi low pass filter, but I'm a little bit confused about the result.
Transfer function
It comes out that it is a second order filter, but it should be a first order filter. What I'm doing wrong? How should I proceed? I know that I could find the transfer function just by putting the two impedances of the capacitor and the inductor equals, but I would like to find it using another method. Thank you.
    \$\begingroup\$ but it should be a first order filter. No, it should be a third order filter as there are 3 reactive components in the circuit. However C1 is in parallel with the input voltage Vin so C1 effectively does nothing making this a second order filter. \$\endgroup\$ Oct 6, 2017 at 9:24
  • \$\begingroup\$ So in the frequency response plot there should be three pole? \$\endgroup\$ Oct 6, 2017 at 9:29
  • \$\begingroup\$ In an RC filter, R between input and output, C between output and ground. How many reactive components are there. If you do not know the term reactive component then Google that. Why would there be three poles? What is a pole and how does it relate to the transfer function? Does the transfer function have 3 poles? \$\endgroup\$ Oct 6, 2017 at 9:30
  • \$\begingroup\$ Yes sorry, I've immediately deleted my comment because I realized that I was wrong, anyway I still does not understand why it comes out that it is a second order filter from the formula. \$\endgroup\$ Oct 6, 2017 at 9:34
  • \$\begingroup\$ Normally the CLC filter as in your drawing is used with a source having an output resistance and not like this, input directly at Vin. Because if you define Vin at the input, C1 just follows that voltage and does nothing else. \$\endgroup\$ Oct 6, 2017 at 9:34
Unfortunately, I could not visualize the circuit you have posted but according to the comments and answer left by Bimpelrekkie, this is a pi filter. Indeed, if there are three energy-storing elements with independent state variables, you have a 3rd-order system. In your case, without a source impedance, the first capacitor plays no role in the input-to-output transfer function. It would indeed if you were to calculate \$Z_{in}\$ but with a 0-ohm source impedance, it is transparent to determine \$H(s)=\frac{V_{out(s)}}{V_{in(s)}}\$.
To determine a transfer function swiftly, nothing can beat the Fast Analytical Techniques or FACTs as described here and here. Please consider the below drawing where I have added the basic parasitic elements found in simple inductive and capacitive models. These elements play a role in the frequency response and cannot be neglected if you work in the RF field or in switching converters. These models can of course be made more complicated but then you increase the system order and the difficulty to solve the transfer function goes up significantly.
Schematic of the 2nd-order LC filter
First, you start with \$s = 0\$: open the caps and short the inductor. The gain in this mode is 1. Then, to determine the circuit time constants, reduce the excitation \$V_{in}\$ to 0 V (replace the source by a short circuit) and determine the resistance "seen" from each of the energy storing elements in this mode (assume in your head that you probe the component terminals with an ohm-meter). Inspecting the sketches we have:
\$\tau_1=\frac{L_1}{R_{inf}}\$ and \$\tau_2=C_2(r_L+r_C)\$
Then, put one of the energy-storing elements in its high-frequency state (a cap is short circuit and an inductor is open circuited) and "look" at the resistance offered by the other element:
\$\tau_{12}=C_2R_{inf}\$ and \$\tau_{21}=\frac{L_1}{(r_L+r_C)}\$
The denominator \$D(s)\$ of this transfer function is given by:
\$D(s)=1+s(\tau_1+\tau_2)+s^2\tau_1\tau_{12}=1+s(\tau_1+\tau_2)+s^2\tau_2\tau_{21}\$. If you assemble the above results, you obtain the denominator expression:
\$D(s)=1+sC_2(r_L+r_C)+s^2L_1C_2\$
For the zero, consider the circuit with the excitation back in place. What condition in this circuit would null the response despite the presence of an excitation? When the series combination of \$r_C\$ and \$\frac{1}{sC_2}\$ forms a transformed short circuit: \$r_C+\frac{1}{sC_2}=0\$ which ends up in a zero defined as \$\omega_z=\frac{1}{r_CC_2}\$. This is it, we have it all and can express the complete transfer function:
\$H(s)=\frac{1+sr_CC_2}{1+sC_2(r_L+r_C)+s^2L_1C_2}\$. You must of course put it under the canonical form
\$H(s)=\frac{1+\frac{s}{\omega_z}}{1+\frac{s}{Q\omega_0}+(\frac{s}{\omega_0})^2}\$ but I leave it to you.
The cool thing with the FACTs is that I did not write a single equation but did just inspect the circuit to determine its time constants. I can go back to the drawings in case I spot a mistake and corrections are easy and fast. A highly-recommended skill to acquire if you have to determine transfer functions! : )
Mathcad calculations and graphs
I realize that I offered a simplified expression in which the first capacitor was removed. Actually, as correctly pointed out by Bimpelrekkie, this filter is associated with a source featuring an output resistance so that it combines with the first capacitor and forms a true 3rd-order filter. As a matter of fact, it does not change the path to determine the transfer function using the FACTs as shown below.
Just by determining the time constant of the circuit when the excitation is set to 0 V (replace \$V_{in}\$ by a short circuit, you can step by step, determine the transfer function of this 3rd-order circuit without writing a single line of algebra! If you made a mistake at the end, spot the guilty drawing, fix it and you're all set. The below Mathcad sheet shows the final result with a formula put under a nice polynomial form.
I have derived a reference transfer function using Thévenin but it would be quite difficult to develop and rearrange it under a meaningful form. With the FACTs, this is easy and swift. Give it a try and you won't go back to classical analysis : )
You are effectively solving a second order filter as the first capacitor is in parallel with Vin. There is nothing that C1 can do, it can have a lower impedance at higher frequencies but then voltage source Vin would simply deliver more current. You could remove C1 and at Vout nothing would change.
This is how such a filter is really supposed to be used. Note that I added R1 which allows C1 to do some low-pass filtering.
