I have used the "Copy Room Formats" before in altium designer for PCBs that have duplicate circuits and it worked fine. But now for the first time i have placed in the PCB Room ( that i want to copy ) components on both sides of the PCB.
The Problem: when i copy the format : the Traces , Vias and buttom layer components are copied properly , BUT the Top layer components are being copied in a CRAZY way best described as if you have flipped the PCB. A Picture is worth thousand words :
( Notice in the Copied Room how the IC body (U14) is on the bottum layer but the pads are on the top layer )
Question : does anyone faced similar issue ? and how to solve ? does anyone know the proper way of copying rooms (with parts on both sides)
Note: I'm working in Altium 15.0. , and i have used Flip Board in View menu when i was routing the buttom layer.
Thanks!
