I have read this sentence below in a paper which describes a low noise amplifier. I can't understand the reason why cascode transistors contribute little to overall noise in an OTA?. Can someone explain me the reason?
Also, I search in the group and I have found a similar question which has posted one year before but the answers don't help me.
Noise contribution of a device at the output will be multiplied by the gain from the noise source input to the output. Voltage gain for a transistor can be approximated as $$A_v = \frac{Z_d}{Z_s},$$ where \$Z_d\$ and \$Z_s\$ are impedances seen at drain and source respectively.
For a cascode device \$Z_s\$ is high since it sees the output impedance of a transistor. So its gain is very small, consequently its noise contribution will be negligible compared to the other devices which will have high gain multiplied by the noise sources.
Cascodes are normally used when you want to include a source degeneration resistance. So the value of R is going to be high anyway.
