i have a problem with this code, because in the RTL simulation, the output Cookie appears as StX. I don't know why this is happening since i don't know verilog well.
Can someone help me?
module dispenser(
CLOCK, SReset,
SBCD, Cookie, valor,
reciba
//Port declaration
input CLOCK;
input SReset;
input [3:0] valor;
output reg reciba;
output reg [3:0] SBCD;
output reg Cookie = 0;
always @(*)
        if( valor >= 4'b1000)
          begin
            Cookie = 1;
             SBCD = valor - 4'b1000;
             reciba = 1;
          end
        else
          begin
            Cookie = 0;
            SBCD = valor;
            reciba =0 ;
          end
endmodule
and this is my testbench
`timescale 1 ns/ 1 ns
module vendingMachine_tst();
   //Parameters
   parameter TCK = 20; // clock period in ns
    parameter CLK_FREQ = 1000000000 / TCK; // Frequenzy in HZ
   //general purpose register
    reg eachvec;
    //Internal wire and reg declaration
    reg [3:0] TB_Un_US;
    reg [3:0] TB_Dos_US;
    reg [3:0] TB_Cinco_US;
    reg TB_Clock;
    wire [3:0] TB_SBDC;
    wire TB_Cookie;
    vendingMachine vM1(
      .Un_US(TB_Un_US),
      .Dos_US(TB_Dos_US),
      .Cinco_US(TB_Cinco_US),
      .SBCD(TB_SBDC),
      .Cookie(TB_Cookie),
      .CLOCK(TB_Clock)
initial
begin
// code that executes only once
// insert code here --> begin
   TB_Clock <= 0;
// --> end
$display("Running testbench");
end
always
// optional sensitivity list
// @(event1 or event2 or .... eventn)
   #(TCK/2) TB_Clock <= ~ TB_Clock;
initial begin
// code executes for every event on sensitivity list
//Caso 1: El cliente entrega justo el precio de la galleta
    #0     TB_Un_US <= 4'b0001;
   #6000  TB_Dos_US <= 4'b0010;
   #60000 TB_Cinco_US <= 4'b0101;
//El cliente supera el precio de la galleta
 // #0   TB_Un_US <= 4'b0001;
//  #60   TB_Un_US <= 4'b0001;
//  #600  TB_Cinco_US <= 4'b0101;
//  #6000 TB_Dos_US <= 4'b0010;
////El cliente no completa el precio de la galleta
//   #0   TB_Dos_US <= 4'b0010;
//  #6000  TB_Un_US <= 4'b0001;
//  #600000 TB_Un_US <= 4'b0001;
 #(TCK*300000) $finish ;
@eachvec;
// --> end
end
endmodule
  • \$\begingroup\$ What is the value of valor that you're feeding in? \$\endgroup\$ – Dave Tweed Oct 7 '17 at 0:16
  • \$\begingroup\$ @DaveTweed it's here electronics.stackexchange.com/questions/333091/… but SBCD always seems to be 0000 and i don't know what i'm doing wrong \$\endgroup\$ – Mel J Oct 7 '17 at 1:18
  • \$\begingroup\$ Oh, so this is essentially a duplicate question, then. \$\endgroup\$ – Dave Tweed Oct 7 '17 at 1:52
  • \$\begingroup\$ @DaveTweed i had to ask this separately because the output here is different from the other one \$\endgroup\$ – Mel J Oct 7 '17 at 1:53
  • \$\begingroup\$ But the underlying issue is exactly the same -- you haven't stated what the inputs to the module are. Show us your test benches! \$\endgroup\$ – Dave Tweed Oct 7 '17 at 10:30
