10
So for a practical definition, the torque constant Kt specifies how many Nm of torque you'll get from the motor at a certain current? Is a bigger Kt always better?
I am more confused about the backemf constant Kemf. This is the amount of back EMF produced by the motor running at a certain speed. Does the back EMF limit the voltage the motor can accept and hence it's speed?
Would an ideal motor have a very high Kt and very low Kemf?
What happens if the back emf voltage reaches the input voltage, does the motor stop running?
Thank you for any answers, Fred
4 Answers 4
15
Hmm. I think you're a little confused. Back-emf limits the motor speed because it dictates how much voltage you need to achieve a given speed.
No. (The symbol \$K_e\$ is usually used for the back-emf constant, by the way.)
If you use SI units (Nm/A for \$K_T\$, V/(rad/s) for \$K_e\$), then \$K_T = K_e\$ for DC motors and permanent-magnet synchronous motors (aka "brushless DC"), and depending on the type of motor and how you define \$K_T\$ and \$K_e\$, the ratio of the two should be a fixed proportionality constant.
Proof of why this is true for DC motors:
At constant operating point (constant speed, voltage, current, torque):
  • \$V_T = K_e \omega_m + IR\$
  • \$T_m = K_T I\$
(\$V_T\$ = terminal voltage, \$\omega_m\$ = motor angular velocity, \$I\$ = motor current, \$R\$ = motor resistance, \$T_m\$ = torque, including frictional losses)
Electrical power in = \$V_T I = K_e \omega_m I + I^2 R\$
mechanical power out = \$T_m \omega_m = K_T I \omega_m \$
Losses = \$I^2 R\$
Conservation of energy means electrical power in = mechanical power out + losses
This is true if and only if \$K_e = K_T\$.
No -- what happens is that the ability of the motor to produce torque decreases with speed. Back-emf voltage "uses up" voltage from the electrical power source; the remaining voltage available to the motor is what's left for IR drop in the motor and the inductance drop \$L \frac{dI}{dt}\$, and since torque is proportional to current I, the available torque decreases. The system reaches equilibrium at some point where the electromagnetic torque matches the motor's mechanical load. If you increase the mechanical load, current will increase to match that torque as speed slows down, making more IR drop voltage available.
No. Rule of thumb with DC motor selection (also true for brushless DC motors to a large extent) -- pick a motor with a \$K_T\$ and back-emf constant such that the supply voltage you have available is well-matched with the back-emf at your maximum speed. You usually want back-emf voltage to be 80-95% of the supply voltage, but the exact number depends on the load torque and the IR drop in the motor at that operating point.
If you pick a \$K_T = K_e\$ too high, you'll run out of voltage and won't be able to achieve the speed you need. If you pick a \$K_T = K_e\$ too low, the current needed to achieve the torque you need will be higher than necessary.
Kt is the ratio of torque output to current input so your initial definition is correct.
Is a bigger Kt always better? Not really. It depends on your application. You could conceivably need lower torque for some application. For instance an application where you wanted a higher speed. Typically the faster a motor spins, the less torque it generates.
This is due to the Back EMF generated. With the power supply voltage remaining constant, as you commutate the motor faster, the Back EMF increases and the current decreases thereby lowering the torque. This is to satisfy Newton's third law. The Back EMF doesn't really limit the voltage a motor can accept (though it is limited). But in general, you need a higher input voltage to overcome the Back EMF and attain higher speeds.
There is no such thing as an ideal motor. It depends on your application. You may want a high Kemf in the case of sensorless operation where you are using the Back EMF for position and speed feedback. But a high Kemf limits you in other areas. It's always a trade off.
The input voltage is the sum of the Back EMF and the voltage drop across the motor so the motor will most likely stall before the Back EMF reaches the input voltage level.
Further reading:
http://www.aveox.com/DC.aspx
http://www.micromo.com/motor-calculations.aspx
Motor and speaker are perfect linear translators of voltage to velocity, current to torque. Exact positive voltage will cause exact positive speed. For negative - the same. Exact load will cause torque and will be seen as exact current. Exact antiload will cause opposite torque and will be seen as reverse current.
  • What is back EMF ? It is voltage generated by motor as if it was a generator.
  • How high back EMF is ? For mechanically lossless motor it is same as applied voltage.
  • When back EMF is same as input voltage ? When motor is free spinning with zero torque, doing zero work, consuming zero current.
  • So what if motor is mechanically loaded ? The motor will slow down exactly to equilibrium of torque and load. Back EMF will be less than voltage. The voltage difference divided by current will be like a resistor, but heat will dissipate mechanically, not electrically.
Ideal motor is as small, strong, fast and lossless as law of energy conservation allows.
The ideal motor must have high Kt yes. The stronger the magnets the lesser the current to cause same reaction of copper wire.
The ideal motor must have high Kemf yes. The lesser amount of wire loop turns the lesser the voltage needed to reach same velocity.
2 examples and 1 mystery:
Example 1: Load with constant mass and no friction. This is most common and practical. Motor translates current into acceleration.
Example 2: Magnet levitates over superconductor. The torgue is equal to weight. Means there is constant circular current in superconductor with zero voltage, opposite zero emf, zero velocity.
Mystery of Speaker: To cause exact and local air pressure of acoustic wave it needs exact what ? Travel distance, velocity, acceleration or torque ? There is some fluid dynamics or something there.
In addition to Kt = Ke (true for SI units, Torque in Nm, Ke in volts/rad/sec), be aware that for a sinusoidal back EMF, the driving voltage for the motor (from a 3-phase bridge) is approximately 1/3 of the DC link voltage. Thus, if the DC link voltage available is 300V, the motor should be rated for 100VAC at the desired operating speed. (Applies to PMAC motors - some (non-sinusoidal back EMF) Brushless motors are speed rated for the DC link voltage). The torque and speed formulae are also approximately correct for induction motors.
  • \$\begingroup\$ The way sine drive is actually done, the peak sine wave voltage is equal to the DC link voltage. Not 1/3 of the DC link Voltage. A 240V induction motor receives a peak voltage of 240 * sqrt(2) = 339 V. The DC link voltage on a 240V VFD will also be 339V. Obviously I am ignoring small losses due to rectifier voltage drop, etc. But those would not account for the factor of 3 that you are talking about. \$\endgroup\$
    – user57037
    Commented Oct 4, 2020 at 5:29
